DIY ubolt flip kit
Old Jan 28, 2013 | 06:22 PM
Dreidel's Avatar
DIY ubolt flip kit
Ok so I was doing some research on fj80 axle swaps on the Ih8mud forums and there is a guy on there that took some square ubolts, notched the bottom of the top spring pad, made a plate to go across the springs and put it all together.
Now if I was going to do this I would plate the entire spring pad and cut a tube in half and weld it in there to make a good solid mount.
I thought it was a great idea and a good was to save some money. just wanted to here your opinions on it
Btw wasn't too sure which section to post this in but now that I'm thinking about it probably should have gone in the fab shop, oops.
Old Jan 29, 2013 | 05:05 PM
Dreidel's Avatar
i think this would be a cool setup will get some pics up to help people understand what im talking about because im not real good at explaining stuff
Old Jan 29, 2013 | 06:09 PM
Dreidel's Avatar
here they are i couldnt get the ubolts to be completly solid all the way around due to teaching myself 3d autocad but you guys get the idea
Old Jan 30, 2013 | 05:54 AM
Dreidel's Avatar
no opinions at all?
Old Jan 30, 2013 | 06:59 AM
SCToy's Avatar
Why not just buy some round u-bolts at the auto parts store that fit your axle and drill out a plate? Can easily make your own the conventional way.
Old Jan 30, 2013 | 07:03 AM
dropzone's Avatar
Fossilized
Why?.
Old Jan 30, 2013 | 07:11 AM
waskillywabbit's Avatar
Removed
Old Jan 30, 2013 | 07:17 AM
Dreidel's Avatar
-Because I can
-Everywhere locally charges 20 per set
-I know they are bent up on the ends so they don't flex and bow I wasn't focused on that to much when I drew that up
- why not
- mine are square and I have extra square ones laying around
Old Feb 20, 2013 | 12:49 PM
Dreidel's Avatar
bump is there a specific reason not to do this or not
Old Apr 14, 2013 | 01:13 PM
NorthIdahoyota's Avatar
Seems like it would put way more load on your spring mounts. Also if a u bolt works its way loose your axle will fall off
Old Apr 14, 2013 | 02:26 PM
Dreidel's Avatar
I don't really have any arguments against the ubolt working loose point but I've personally never heard of a spring perch folding in on itself while under a load and highly doubt the weight of the axle could rip the perch off the housing so I don't aero the more stress on the perches as a valid point in the discussion ( not being a dick just explaining)
Old Apr 14, 2013 | 03:02 PM
Besides axle weight there is also the torque of axle wrap. Probably not gonna break but still another factor. $20 isn't bad for the security of new bolts that go around the axle. is that a model of your actual axle? My perches look quite a bit shorter and wouldn't work for this anyway
Old Apr 14, 2013 | 03:44 PM
Dreidel's Avatar
Where are you getting prices from aroun here $20 if ubolt is one side of the axle I got 6 new ubolts but they are square
That was a estimation I realized after looking under there to see they were quite a bit shorter than expected might make new ones
My step dads 93 runner he had is for sale now for 450 dollars and still runs so I might buy it and put in a 300 d60 I know of and 14b rear and not worry about this whole thing but not forsure yet because I got laid off Friday
Old Apr 14, 2013 | 04:26 PM
I bought the u bolts off rock auto and it cost like $6 a bolt.your method would work I was just pointing out a few downsides to this way. If it works for the fj80 guys it should work for you, just not the best way imo
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
pickle6415
Apr 14, 2021 06:20 AM
RyanJ989
11
Apr 7, 2021 09:41 AM
Patrick1976
Sep 15, 2015 11:33 PM
