detroit lockers
Old Oct 9, 2005 | 08:20 PM
gilkey's Avatar
detroit lockers
How hard is it to remove detroit lockers from a first gen 4runner and about how long does it take?
Old Oct 10, 2005 | 03:50 PM
crawler#976's Avatar
part one - removing the rear third member
with an impact wrench and hand tools this should only take an hour tops...
place the vehicle on jack stands
drain the rear diff
remove the rear brake lines, cap the ends with vacuum line caps to prevent the fluid from draining
remove the parking brake cables
remove the 4 nuts on the inside of the axle flange
pull the axle assembly out, or pull it out about 4" and support the axle to prevent damaging the seal
remove the 4 bolts from the rear d'shaft/third member flange
remove the nuts from the third member
place a floor jack under the third member flange and bump it up until the gasket seal seperates from the housing
remove the third member - it's heavy
reassemble in reverse order. it's a good time to replace rear axle seals. I don't use a paper third member gasket - RTV works fine. fill the diff, bleed the brakes...
______________________________
part two
removing the detroit will require you to completely disassemble the third member. it will require a complete setup to be functional again - a master install kit is required and the gears will need to be setup by an experianced installer.
mark the bearing caps w/ a punch so they can be assembled together when your done. I put two punch marks on the right cap and lower bearing seat...
loosen the adjuster nuts and remove the bearing caps
remove the detroit w/ ring gear
remove the ring gear - this is a bit of a chore, it's almost a press fit
remove the bearings from the detroit w/ a press. if tyou don't have a press, your installer should be able to remove them for you
_________________________________
the front end is similar - the best directions for that are on the 4X4Wire site...
http://4x4wire.com/toyota/maintenance/front_end/
TheBFA
Feb 15, 2020 06:55 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
