Correct Caster for Dana 44 SAS
Old Dec 4, 2006 | 11:12 AM
Ringmaster's Avatar
Ok guy's, gal's,
How many degrees of positive caster did you use when rotating the inner knuckles on your Dana 44 SAS?
This is assuming the weight of the vehicle is on the axle at the time of setting the degree's of caster.
Thanks
Don
Old Dec 4, 2006 | 11:40 AM
Flygtenstein's Avatar
The weight of the rig as well as set ride height front and rear since that impacts it too.
Old Dec 4, 2006 | 11:55 AM
Ringmaster's Avatar
Well said, I forgot that. Thanks
Old Dec 4, 2006 | 01:16 PM
tc's Avatar
tc
You might have better luck over on www.ttora.com or even Pirate.
Old Dec 7, 2006 | 06:23 AM
4Crawler's Avatar
Stock on the Toyota axle is ~2 degrees:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Steering
Usually can go a little more than that with larger tires.
Yotav6power
16
Mar 4, 2016 07:45 AM
RickyD
Oct 2, 2015 07:53 AM
JookUpVandetti
Sep 24, 2015 02:58 PM
Flying91
Sep 10, 2015 03:41 PM
justdifferentials
Sep 5, 2015 06:52 PM
