Can 4" clear 35"s
Old Aug 13, 2004 | 06:08 PM
Lifted4Runner's Avatar
Can 4" clear 35"s
I wanted to no if a 4 inch lift would be tall enough to clear 35 inch tires on my 1986 4Runner? Thanks for the help.
Old Aug 13, 2004 | 06:18 PM
Yoter's Avatar
Guest
What size rims will you be running and how wide of a 35? What brand lift are you buying? And Welcome to YotaTech BTW. Ben
Old Aug 13, 2004 | 06:28 PM
waskillywabbit's Avatar
Talking Howdy
Tuscaloosa here. Welcome to YT. 4" might be close as I've seen 35s on a couple rigs and most had like 5-6" of lift. Test fit one and see!
Old Aug 13, 2004 | 06:30 PM
Yoter's Avatar
Guest
The only diff I see is you having a 1st gen and mine being a 2nd. I ran 35X12.5's on 8" wide wheels for a few months with little rubbing. But I am not sure on our fender differences.
Old Aug 13, 2004 | 06:46 PM
4Crawler's Avatar
Usually the 4" IFS lifts will require that you run 3.5" or so backspacing on the wheels to clear the lift. This will push the wheels and tires out from the body and increase the likelyhood of rubbing, so usually you need 2" body lift + 4" IFS lift to clear 35s:
Lift vs. tire size info.
Old Aug 14, 2004 | 07:39 PM
I was hoping to get a 4 in. trail master kit because it uses blocks in the rear so i could keep the add-a-leafs, and adjusted torsion bars i already have plus the trail master kit for about 5.5 or 6 in. total lift i just wanted to know for sure i could clear 35"s with that before i got it. Thanks for all the info.
Old Aug 14, 2004 | 08:04 PM
jimbo74's Avatar
5.5-6" should clear fine, however with torsion bars cranked, it probably wont ride the best
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
alexcarey
Oct 14, 2015 06:05 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
