billstein 5125 shock body placement up/down
Old May 13, 2006 | 09:01 AM
dfoxengr's Avatar
ive seen a lot of setups and i just got mine, some people put the body up and the rod/boot down, and some do it reversed. the directions say body up, so why do people put it down?
thanks
-derek
Old May 14, 2006 | 11:16 AM
dfoxengr's Avatar
Old May 14, 2006 | 11:39 AM
Tanto's Avatar
It shouldn't make a difference since your Bilsteins can be mounted can up or can down. Some other shocks are designed to be mounted either can up or can down. Clearance issues may be a factor in your setup where the location of the can may be more ideal in the can-up or can-down position.
Old May 14, 2006 | 01:08 PM
dfoxengr's Avatar
just wondering why the directions say reservoir up?
ill probably go with that unless theres some clearance problem.
-derek
Old May 14, 2006 | 07:03 PM
Robinhood150's Avatar
-derek
Because some people can't read.
Old May 16, 2006 | 11:06 PM
birfieldbuster's Avatar
I have noticed that with the body up less crap tends to build up around the piston to body area
Old May 20, 2006 | 02:58 AM
deathrunner's Avatar
I believe that they are made to point in specific directions to avoid shock fade. I think it has something to do with how they want the gas to press the oil against the valve.
I prefer the body up.
Old May 22, 2006 | 04:40 PM
motomachine11's Avatar
It's for several resons, one is becouse the compression and rebound valving are diffrent. and all the reasons above.
Old May 29, 2006 | 12:00 PM
dfoxengr's Avatar
i mounted them body up like the directions said.
thanks guys.
Blamalam
Mar 12, 2022 07:34 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Bawlzdeep
Aug 2, 2015 08:35 PM
SMOD
Jul 27, 2015 01:45 PM
