air locker questions
Old Jun 25, 2005 | 09:28 AM
big jim's Avatar
Hey all. i have oil comming form around the solinoid at the compressor any one know what might be causing this?
Old Jun 25, 2005 | 09:39 AM
jimbo74's Avatar
bad compressor seal?
Old Jun 25, 2005 | 10:21 AM
big jim's Avatar
it is only coming from one of the solinoids and it smells like 90wt
Old Jun 25, 2005 | 10:43 AM
4Crawler's Avatar
Compressor is oil-less, so likely not from there. Not uncommon for some oil to come out of the solenoid vents. Cause is oil leaking past the seal inside the locker. On my truck, the rear is dry but the front has a little oil on it. As long as the seal is not leaking air to the point the compressor cycles on and off a lot with the locker engaged, it is probably fine. You could contact ARB and ask them about it if you are concerned or need repair parts.
Old Jun 25, 2005 | 07:39 PM
big jim's Avatar
thanks 4 crawler yhe compressor dose not cycle with the locker on and i'll call arb on monday but i think i'm good
Old Jun 25, 2005 | 08:16 PM
User 051420's Avatar
I had this SAME problem. The verdict: bad seal housing...replaced x3, now it doesn't leak.
Old Jun 25, 2005 | 08:31 PM
doink's Avatar
i think i also heard that a clogged diff breather can be the culprit in some manner. maybe im mistaken
Old Jun 25, 2005 | 08:32 PM
Your're entirely correct.
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
A2theK
Jul 12, 2015 10:46 AM
