'90 p/u suspension advice
Old Jan 4, 2008 | 03:21 PM
TastySalmon's Avatar
I have looked around from other posts to find what I'm looking for but haven't had much luck. Finding information for new suspension from past posts for a newb like me can be a little overwhelming.
I have a '90 pickup 4x4. My rear suspension is lifted with 2" blocks and my front has the torsion bars to match the rear. I want to get rid of the blocks and replace the stock springs which are sagging with 2" or 2 1/2" lifted springs that are more rugged than stock and will allow me to carry a heavy load (2 dirt bikes, elk, lots of hunting gear, etc.). What springs would you recommend for this?
I want to loosen my torsion bars because the ride is really stiff. Modifying the front suspension is the most confusing for me. What do I need to do exactly to keep a 2" lift in the front without tight torsion bars? What kit would you recommend for this?
I am not mechanically handicapped. I used to do all of my own work on my past vehicles, though repair and replacements was limited. Is replacing the rear springs something I can do with a lift and basic tools? How about the front suspension? I am running 31x10.5 mtrs and do require good flex with a load.
Thanks for any adivce you might give.
Old Jan 4, 2008 | 06:48 PM
tc's Avatar
tc
For the front, balljoint spacers.
For the rear, Alcan or Deaver
Old Jan 8, 2008 | 09:58 PM
andyinvain's Avatar
deaver makes a great desert racing springs but i dont know how much of that youd do in idaho. you can send your main leaf to deaver in santa ana CA and they can make you a spring set for about 200 per side. then you dont have to move and remount your shackles....
Old Jan 8, 2008 | 11:35 PM
Jay351's Avatar
You could always do the 63" chevy spring mod. ( if you have accsess to a welder ). They will net you roughly 2-3" of lift and since they are from a half ton chevy, they will be able to support big loads.
Old Jan 10, 2008 | 11:25 AM
Yodaforce's Avatar
I have heard that you can pull the torsions out, rotate them in their pivots(splined mounts attached to the control arm) in such a way as to keep them closer to the factory setting, while still giving a little lift. Never tried myself though.
Old Jan 10, 2008 | 11:35 AM
muddpigg's Avatar
maybe use the search option, I know myself and other advised on this same question. Last night.
https://www.yotatech.com/search.php?searchid=4140968 I even did it for you.
nvdesertrunner
May 11, 2020 08:18 PM
89fourrunner
Feb 17, 2016 06:52 AM
juandulce4runner
Aug 21, 2015 07:30 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Vargntucson
Jul 4, 2015 12:15 PM
