88 axle housing.........90 axle shaft....Fit?
Old Dec 10, 2005 | 08:47 AM
Yoda's Avatar
OK,
I found a V-6 rear axle housing/diff for a 88 truck. He says it has 1 bent axle shaft (housing is OK). I still have the axle shafts for the 90 4Runner we parted out. Will they work? (88 = leaf, 90 = coil springs)
BTW this is to install the wide-track axle in the 85 truck
Old Dec 10, 2005 | 09:36 AM
4Crawler's Avatar
Shaft; yes. Problem will be the brake backing plate, specifically where the e-brake linkage attaches. Likely will have to press the backing plate off of the bad and good axle and swap them.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
