4x4 question
22RE? Probably has the same front 4WD setup as the 4Runners and mini pickups. Look for a FSM here to troubleshoot.
www.ncttora.com/fsm
www.ncttora.com/fsm
- http://www.off-road.com/trucks4x4/ar....jsp?id=399612
Not uncommon for the auto hubs to not lock reliably, might pull them off and see if you can see what is wrong inside:
- http://www.off-road.com/offroad/arti....jsp?id=399668
Or replace with manual hubs if possible:
- http://www.4x4wire.com/toyota/tech/autohub/
Is the front drive shaft spinning when you put in in 4WD? How about the front CV axles?
Btw, Wabbit, The vans never had a 22RE motor. n00b
Through 85 they used the 3YEC motor, and after they used the 4YEC motor. Same basic motor as in the forklifts toyota was building at the time.
Sep 4, 2015 09:27 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
