4x4 question
Old Feb 1, 2010 | 05:53 PM
mikes88xj's Avatar
4x4 question
I have acquired a 88 van. I have got everything working on it other than the four wheel drive. Any pointers on what goes out first? Is it electric or vacuum?
Old Feb 1, 2010 | 06:02 PM
waskillywabbit's Avatar
22RE? Probably has the same front 4WD setup as the 4Runners and mini pickups. Look for a FSM here to troubleshoot.
www.ncttora.com/fsm
Old Feb 1, 2010 | 07:03 PM
mikes88xj's Avatar
Negative nothing that I could find, i thumbed through them it gave specs on the transfer case but nothing to trouble shoot.
Old Feb 1, 2010 | 07:17 PM
4Crawler's Avatar
What kind of 4WD system does the van have? Is it manual hubs up front, or automatic hubs or just drive flanges and the automatic differential disconnect setup?
- http://www.off-road.com/trucks4x4/ar....jsp?id=399612
Old Feb 1, 2010 | 08:07 PM
mikes88xj's Avatar
Auto hubs.
Old Feb 1, 2010 | 08:12 PM
4Crawler's Avatar
Not uncommon for the auto hubs to not lock reliably, might pull them off and see if you can see what is wrong inside:
- http://www.off-road.com/offroad/arti....jsp?id=399668
Or replace with manual hubs if possible:
- http://www.4x4wire.com/toyota/tech/autohub/
Is the front drive shaft spinning when you put in in 4WD? How about the front CV axles?
Old Feb 1, 2010 | 08:18 PM
mikes88xj's Avatar
Not sure haven't gotten that far yet. I was wondering what the known problems were. Like vacuum issues, solenoid problems, switches or just hubs.
Mike
Old Feb 1, 2010 | 08:23 PM
DeathCougar's Avatar
Mike
Vans never had ADD, ever. They had the same unreliable auto locking hub setup that the 84-88 trucks had. I would look to that as the first culprit.
Btw, Wabbit, The vans never had a 22RE motor. n00b
Through 85 they used the 3YEC motor, and after they used the 4YEC motor. Same basic motor as in the forklifts toyota was building at the time.
Old Feb 2, 2010 | 01:06 PM
mikes88xj's Avatar
So far since it is raining I have been able to get the push buton unstuck and did watch the front shaft turn.
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
Coreyr384
Jul 10, 2015 11:13 AM
garagespace
Jul 9, 2015 08:37 AM
