315/75-16's under my truck...
Old 11-09-2005, 02:42 PM
BAZ
BAZ's Avatar
(34.6" x 12.4") how much of a pain in the butt would it be to make these fit? Only reason I ask is that I may get a great deal on a set. I'm running 16" tundra steel wheels so that is why I was asking about the 315's. I had planned on going with BJ spacers up front and shackles/ add-a-leafs in the rear but I know it would take more than that to fit these meats.
Old 11-09-2005, 03:02 PM
00Runner's Avatar
Dude, there are like 3 threads on this topic already in just the last week.
Old 11-09-2005, 04:49 PM
Albuquerque Jim's Avatar
If you decide not to do it let me know...I'd like a great deal on a set of 315's I have already done almost everything to make them work
Old 11-09-2005, 05:03 PM
BAZ
BAZ's Avatar
Haha, I might pick 'em up (they're local) and just trade somebody for a smaller size. They're procomp M/T's w/very little use. After reading the other posts it seems like kind of a lot of work for only a little more tire.
Old 11-09-2005, 07:23 PM
Silver_Truck's Avatar
They wouldn't be that hard to fit..I only had to trim out like 1" from my fenders in front for 34 and cut off my pinch weld, I'd get em cut your fenders and see where that takes you. Throw some BJ spacers up front and chevys or some other 2" lift spring in the rear and you'll need a BL unless you want to cut more.
Old 11-10-2005, 11:25 AM
westy44runner's Avatar
Put on a 1" RB body lift combined with BJ spacers and match the rear with shackles/new springs or AAL
That should net you close to 3" if you crank the t-bars just alittle. The procomps run small anyways, the wheels you run with be a determining factor as well...but I'd just go for it. It will be worth it. WHen I lifted my 4runner a couple inches and put 32x11.5s on, the added clearance made a huge difference off road.
though if you dont have any lockers...id put the $$ toward that before trying to make bigger tires fit.
duckhead
170
11-13-2017 06:07 AM
ErikZ1220
09-10-2015 04:53 AM
YotaTruck1986
46
10-31-2006 11:11 AM
Swissdrums
13
04-21-2006 08:46 PM
yoda92
50
08-10-2005 01:51 PM
Quick Reply: 315/75-16's under my truck...
