will 315/75-16 fit ????
Old Aug 8, 2005 | 04:21 PM
yoda92's Avatar
Im wondering if a 315/75-16 will fit witout a body lift. I have donahoe coils wheelers steelies 16x8 4" bs . No rear lift yet ? This will be on a 05 taco. Im sure they will fit but Im wondering if they will rub to bad if I wheel it ?
Old Aug 8, 2005 | 04:24 PM
r0cky's Avatar
Yes, they will rub horribly. Talk to Cedarbarn - he has an 05 Taco with the SAW coilovers, and can give you a better idea of all this. That said, I'm certain the 35s would not fit without major trimming.
Old Aug 8, 2005 | 05:09 PM
Good Times's Avatar
It'll fit but you won't be able to drive with it on. One bump and cya fenders. O yeah, also the tire too since it'll get caught on the body mount. Let's not forget the mud flaps and the bumper, o might as well just strip it all now if you want 35's.
Good luck as it's a venture most all will not want to do at all.
with 285/75/16 you'll experience "plenty" of rubbing. you can run 34" tires for show (street only) but don't even dare on the trails. Talk to Donahoe as they had 34" on their blue 05 but didn't bother to do much trails as they saw the rubbing was not going to be fun.
good luck again
Old Aug 8, 2005 | 06:13 PM
yoda92's Avatar
well I was gonna go with 285s but they are to skinny . since the the 05 looks so much larger than the previous years I think a larger tire would look much better. I think Im gonna go with a 305/70 since they are the same dia and a tad wider. I will be sure to post pics as soon as I get them on. wheelers steelies are suposed to arive tomorrow . Now if I can just decide on the tire and size
Old Aug 8, 2005 | 06:34 PM
Good Times's Avatar
if you plan to do any offroading then i would say 305's will be abit much. do expect severe rubbing. talk to the guys at donahoe for full details on tire sizes.
good luck
Old Aug 8, 2005 | 06:43 PM
Cedarbarn's Avatar
If you are just going for looks I really cannot help you.
But if you are interested in looks and function then I can.
I have a 2005 reg cab 4x4 with the mods listed in my sig below. Here are pics with my lift and 285/75/16 BFG M/T tires (33"). I get a lot of attention. My tires rub the frame, but nothing serious. A wider tire or taller tire will be a major problem offroad without a bigger lift/cut fenders, spacers...
I have about 2.5" of suspension lift.
Tires aired down to 16-18 lbs have great traction. They are mounted on stock 16x7 rims and hold the bead just fine. I hope your rims fit over the front calipers. Check this before you mount tires on them so you can return them if they do not fit!!!
35" tires with my lift will not work. It would require fender cutting at minimum. I am running stock 4.10 gearing with the 33"s and want to re-gear to 4.88. I am doing a lot of wheeling with my 33" tires, and have no need to run 35" tires with what I am doing. (2 and 3 trails at BMRA, cleared a short 4 with no problems)
If you are looking to wheel it with the stock suspension then go for the 265/75/16 tires. They will fit the 2005 with no rubbing. My buddy OB runs these tires and will out wheel me any day of the week.
Old Aug 8, 2005 | 07:32 PM
yoda92's Avatar
As I have stated im not running stock suspension I have donahoe coilovers, rear is stock for now but I dont think the rear is a problem even if I do run stock. As far as the wheels go , according to wheelers they have had no fitment issues with the 05 and there steel wheels( keeping my fingers crossed). the wheels have a 4" backspace so that should fix any upper a arm rubbing. I have a v6 so I dont think i will need to re-gear .
oh yea your truck looks pretty sweet. The 285 look pretty big in the photos . Just a little skinny. Well thanks for your advise . I think im gonna end up with 305/70s
Old Aug 8, 2005 | 08:04 PM
r0cky's Avatar
Just a warning - with the 305s you are still going to have major rubbing off-road, and probably even a good deal on road. And no, just because the wheels have 4" backspacing, that doesn't mean you won't have trouble with the tire hitting the upper a-arm. I guess you'll just have to wait and see when you put them on ... but I can tell you right now it will involve cutting, regardless.
Old Aug 8, 2005 | 08:10 PM
Cedarbarn's Avatar
Good luck with the setup.
Old Aug 8, 2005 | 08:11 PM
yoda92's Avatar
ok well I dont know what the heck im gonna do now, who woulda thought 1" could make that much difference !!
Old Aug 8, 2005 | 08:15 PM
Cedarbarn's Avatar
It depends upon what you are going to do with the truck. If you are going to take it offroad and flex the suspension to its limits then it will make a difference.
Old Aug 8, 2005 | 08:37 PM
yoda92's Avatar
yea I do plan on taking it off the road on some trails and stuff. I just dont want to get 285s and then regret it later !!! I wish someone could really tell me if 305s would work or not .Like someone that has actually ran them with a similar setup .
Old Aug 8, 2005 | 08:41 PM
r0cky's Avatar
I think everyone in this thread is telling you that they will "work" but not without major trimming/cutting/etc. and off-road, well ... off-road it will tear up the fenders.
Old Aug 8, 2005 | 09:01 PM
Cedarbarn's Avatar
Its your truck and your money!!
Go for it!!
You will be the first 2005 that I have heard of with 35" tires, front coil over lift (good for about 2.5 inches before things get ugly) and no rear lift!
I want to see it!!
(dont come crying to me if everything rubs, you have been warned.)
Old Aug 8, 2005 | 09:03 PM
r0cky's Avatar
Go for it!!
I want to see it!!
I have seen some 2005s with 35s. Even with 4" of lift it looks like they'd tear the hell out of many things.
Old Aug 8, 2005 | 09:06 PM
r0cky's Avatar
Actually, strike that, even the most irresponsible guy I've ever known has never set up a 2005 with anything more than a 285 -- and that is with FOUR inches of lift.
Old Aug 8, 2005 | 09:24 PM
yoda92's Avatar
Go for it!!
I want to see it!!
Im not considering 315s anymore . Its between 285s and 305s both are 33" 305s are 1/2" wider per side approx depending on brand of tires. So lets say I clear the a arms what will I need to worry about? When you guys say fenders im assuming your talking about the inner plastic which I can trim , I can remove the mud flaps.
Old Aug 8, 2005 | 09:43 PM
Jboy's Avatar
Put a 2" body lift, that should give more room for the 305s
Old Aug 8, 2005 | 09:49 PM
yoda92's Avatar
oh and 1 more thing on the instructions for the coiovers recomend 285/75 with a 16x8 with a 5" backspace now correct me if Im wrong but isint that gonna cause serious rubbing with that backspace?
Old Aug 8, 2005 | 09:57 PM
Silver_Truck's Avatar
Are there BLs for the 05s yet? If so get a 1 or 2" BL and you should be fine also it'll make adding sliders easier. If not contact Roger Brown at 4Crawler offroad and he can probably make one up for you. I'd say your going to need alot more then 2.5" of lift. With my truck I had a 2" BL and cranked up t-bars and still needed to take more then an inch out of the back of my fenders to stop rubbing with 34s that are only 10.5" wide...I realize our trucks aren't nearly the same but IMO our fenderwells look to have more clearence.
