285 v 305
Old Sep 20, 2006 | 01:51 PM
Anthology's Avatar
285 v 305
What is the difference between a 285/75/16 and a 305/70/16? I thought they were both about the same, but how come the 305's are like $30-$40 more?
Old Sep 20, 2006 | 01:53 PM
Localmotion's Avatar
just wider.
295/75/16 is a taller tire.
Old Sep 20, 2006 | 01:55 PM
seanz0rz's Avatar
Guest
http://www.s-series.org/htm/calc/tiresizeconv.htm
285/75r16 = 32.8x11.2 taller, skinner
305/70r16 = 31.8x12 shorter, fatter.
Old Sep 20, 2006 | 01:56 PM
mastacox's Avatar
285/75/16 = Approx 33x11.50
305/70/16 = Approx 33x12.50
Old Sep 20, 2006 | 01:58 PM
Anthology's Avatar
ok thanks
Old Sep 20, 2006 | 02:04 PM
mastacox's Avatar
You're just a slight bit off...
285/75r16 = 32.831 x 11.22
305/70r16 = 32.811 x 12.01
295/75r16 = 33.421 x 11.32
The 285 and 305 are essentially the same height, but the 305 is 3/4" wider.
Old Sep 20, 2006 | 02:16 PM
Bazooka_cow's Avatar
i feel like i am in math class again . just kidding. i didn't really understand the converstions so this thread helped me to, just thought i would throw some humor in there.
Old Sep 20, 2006 | 06:47 PM
AH64ID's Avatar
conversion info... crash course
285/75/16
285 is the section width (WIDTH)
75 is the ratio of width to height (SIDEWALL)
16 is the rim
to convert to normal numbers... divide the 285 by 25.4(cm/in) this gives you 11.22
take 11.22 and mulitply it by the ratio or .75 this is 8.42
Multiply 8.42 times 2 (there are two sidewalls to count) and add 16 (rim)
This gives you a 32.83x11.22R16 Tire
Now like any 35x12.50R15, this varies my mfg, but its a good start. Most mfgs have size specs on their website.
jaretstuff
Oct 22, 2015 05:25 PM
4runner4me
Feb 24, 2004 09:16 PM
mikes97
Nov 11, 2003 11:55 PM
ufjaz
Dec 19, 2002 03:46 PM
Mudd Runna
Dec 5, 2002 10:24 AM
