Changing T100 Starter...
Usually a tight fit, cramped location but not terribly hard to do in terms of tools or skill required. Best option is to repair the existing starter, especially if it just has worn copper contacts in the starter solenoid, which is the #1 most common problem. $10 or so and you can get the parts, takes less time to repair the starter than it would to drive down to the parts store for the replacement unit:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
worth repeating:
It's only about a 1, but removing it for the first time makes it feel like a 5. Figure 30 minutes to an hour to figure out how to arrange the wobbles in sequence to reach the bolts and break them loose. That's the hardest part.
Try to rebuild it yourself. Once you get it out you'll be amazed at how simple it is to replace the contacts. Then you will have an OEM starter with new contacts that should last the life of the truck.
You need to open it up and see or give the dealer the part number off of it (also requires getting it outta there). For some reason they used the offset contact on different sides, different Ts (least that's what I got from the local parts guy). You should be able to buy all 3 and return the unused one.
Originally Posted by Josh C
Does anyone have which contacts I will need for my starter?
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
