99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
bell noise when shifting auto trannsmission
Old 07-15-2005, 11:21 AM
elnido's Avatar
I get the sound of a muted bell, very slight, when shifting into reverse or from reverse to drive with my auto tranny. Seems like it's always been there, can't tell if its getting worse because I only recently started paying attention to it. Does anyone know what this might be?
thanks
Old 07-15-2005, 06:42 PM
02SE's Avatar
My best guess would be that you need to lube the slip-joint in the driveshaft. If it gets dry, from infrequent, or non-existant lubing, it can make a noise like you described.
The driveshaft is a hollow tube, which can amplify the noise a bit, making it loud enough to hear.
Old 07-15-2005, 10:57 PM
DudeBud's Avatar
thats what i was thinking the driveline. how much slop is there in the rearend.
Old 07-16-2005, 04:32 AM
gohawks's Avatar
I get that "ping" sound as well when I shift into reverse.
Old 07-17-2005, 11:02 AM
TechWrench's Avatar
Chances are, if you are getting a 'bell' ring from the driveshaft when shifting from forward to reverse or the opposite, you are too late for lubing the u-joints. Most likely you need at least one replaced. If there is enough play for the joint to create an impact ring when changing directions, it is to late for grease.
Old 07-17-2005, 11:03 AM
4RocRunner92's Avatar
I get that kick that jerks the whole vehidcle when I shift from R to D or D to R.
Old 07-18-2005, 07:12 AM
elnido's Avatar
the only regular lubing I've done since owning the vehicle is the Zerks (oil change place does it). Whats the prognosis Dr? How long does this part have to live now?
Old 07-19-2005, 11:29 AM
TechWrench's Avatar
Even though they were lubed by the oil change place (assuming they actually did it), lubrication is not a guarantee that a mechanical part will not fail. Especially with u-joints, there are many variables that will affect joint life. Not all of which can be controlled. If yours have in fact started to go bad, it is only a matter of time before it goes from a simple 'bell' to a clank, vibration, and if left long enough possible catastrophic failure. The earlier you replace bad ones, the less likely that damage can be done to the yokes.
That being said, I wouldn't let it go more than 3-4 weeks before replacing them. And I did mean them. I always recommend that if one is bad, replace both ends while the drive shaft is out. The other one can't be far behind as far as wear goes.
Liadrin
04-25-2022 02:54 PM
Liadrin
09-01-2015 06:44 AM
TransAmBandit
07-28-2015 11:30 PM
CanRunner
07-20-2015 01:29 PM
mlavery85
07-12-2015 10:33 AM
Quick Reply: bell noise when shifting auto trannsmission
