New Nitro Gear packages for your vehicle, now with 1 part number!
Old Aug 20, 2013 | 12:31 PM
justdifferentials's Avatar
Nitro Gear and Axle has led the way for many innovating R&P and axle packages. Now they have simplified the way you purchase gears. With one part number you can purchase your front and rear ring and pinions, master install kits, solid preload spacers, and new yokes if they are required. No more searching around to find the correct install kits and ratios for both your axles!
New Nitro Gear packages for your vehicle, now with 1 part number!-7vmofew.jpg
New Nitro Gear packages for your vehicle, now with 1 part number!-ikdsdyw.jpg
Do you really need new gears in your axles?
It is a common misconception that Re-Gearing a vehicle is only for Hardcore Off-roaders or for huge oversized tires. In fact, most of the late model vehicles we produce aftermarket ratio’s for are daily driven vehicles with slightly oversized tires. In an effort to improve fuel economy, Late model overdrive transmissions are geared very high which means RPM’s are very low on the highway. When even a slightly taller tire is installed the RPM’s are reduced below acceptable levels that the engine was designed to run. This causes constant shifting out of overdrive, sluggish acceleration, poor economy and rapid wear on the transmission and other components.
By changing the Ring & Pinions in your vehicles differentials, you can match the ratio to the tire size to bring the RPM’s back to where the manufacturer intended. Typically it is recommended to select a ratio slightly lower (higher numerically) than what the math will tell you. This will help accommodate increased rolling resistance, wind drag, and added weight of aftermarket accessories and gear.
If you have any questions or need a quote, contact us
Old Sep 10, 2013 | 09:56 AM
Bringing this back up, we have part numbers for tons of makes and models. If you don't see yours let us know and we will see what we can find!
Old Sep 18, 2013 | 08:35 AM
Here are some of the popular Toyota packages. They include everything you need to re-gear the front and rear axles of your Toyota:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
1991-1997 Toyota Land Cruiser 70 & 80 Series Front & Rear Gear Package Kit:
4.56
4.56 with OE lockers
4.88
4.88 with OE lockers
5.29
5.29 with OE lockers
1998-2007 Toyota Landcruiser 100 Series Front & Rear Gear Package Kit:
4.30
4.30 with oe rear locker
4.88
4.88 with oe rear locker
2008-Present Toyota Land Cruiser 200 Series Front & Rear Gear Package Kit:
4.88
Toyota Landcruiser II, Bundera LJ, RJ, KZJ 70/73/78 Front & Rear Gear Package Kit:
4.30
4.56
4.88
5.29
07-09 FJ Cruiser, 03-09 4Runner Prado 120, 05+ Hilux Front & Rear Gear Package Kit:
4.56
4.56 with OE rear locker
4.88
4.88 with OE rear locker
2010+ FJ Cruiser, 4runner, Prado 150 Front & Rear Gear Package Kit:
4.56
95.5-04 Tacoma, 00-06 Tundra & Sequoia Front & Rear Gear Package Kit:
4.56 without Rear locker
4.88 without Rear Locker
5.29 without rear locker
05+ Tacoma Front & Rear Gear Package Kit:
4.56
4.88
4.88 with OE rear Locker
07+ Toyota Tundra Front & Rear Gear Package Kit:
4.88 w/ 5.7L
4.88 w/ 4.6L or 4.7L
If you have any questions, call or email us:
Old Sep 20, 2013 | 10:46 AM
On the fence about re-gearing your vehicle?
Check out these two video links for more info about why you should change your gears, and how it is done!
NITRO GEARS AND AIR LOCKERS INSTALLED!
Nitro Gear & Axle – 4.88 Ring & Pinion sets
Old Oct 1, 2013 | 07:57 AM
Better MPG, faster acceleration, and less stress on your drivetrain are just 1 part number away!
Give us a call to learn about the packages we offer for your vehicle.
Old Oct 28, 2013 | 07:17 AM
Nitro Gear & Axle Gear Packages for many popular applications are in stock. One Part Number includes everything you need to re-gear your 4x4.
Many applications including Toyota FJ Cruiser, Land Cruiser, Tacoma, Tundra. Ford Super Duty, GM Duramax, Dodge Cummins, Jeep YJ, XJ, TJ, ZJ, WJ, WK, JK and many more. You can find them here:
Nitro Gear Packages
Call or email us for more info!
Old Nov 7, 2013 | 07:39 AM
We stock gears and axles for many different vehicles. From tow rigs, to trail rigs and everything in between. Here is the Bushwacker SEMA truck, it features Nitro Gears, differential covers, and 40 inch tires!
Old Nov 21, 2013 | 07:56 AM
-Ring & Pinions
4.56
4.88
5.29
4.30
4.88
4.88
4.30
4.56
4.88
5.29
4.56
4.88
4.56
4.56
4.88
4.88 w/ 5.7L
If you have any questions or need a quote you can reach our sales staff using the information in our signature!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
