Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
I am back to a toyota yay 1987 toyota pickup paid $671
Old Jul 27, 2016 | 11:02 AM
coolfool's Avatar
well today i bought a 1987 Toyota pick up and paid $671.00 at government auction was running wen it RAN WHEN SEIZED from a DUI. They said its been sitting for 3 years....... So i am gonna have to at least have to drain the tank get and get a battery and oil change to then try starting it. After that will prob need spark plugs wires and tires then go from there but first i need to find transport from Englewood, Tennessee to me in spartanburg sc
so as for the fuel tank any one no if theirs a drain plug on it ? for the 87 year ?
no rust from what i can see in pictures!!! so that's a great start and i figure at that price its a great project truck any suggestions are if you no anyone that can transport this for me let me no don't want to spend to much
what do you guys think did i score are not ?
Attached Thumbnails I am back to a toyota yay 1987 toyota pickup paid 1-3613_34_21.jpg   I am back to a toyota yay 1987 toyota pickup paid 1-3613_34_22.jpg   I am back to a toyota yay 1987 toyota pickup paid 1-3613_34_23.jpg   I am back to a toyota yay 1987 toyota pickup paid 1-3613_34_24.jpg   I am back to a toyota yay 1987 toyota pickup paid 1-3613_34_25.jpg
Old Jul 28, 2016 | 11:44 AM
Terrys87's Avatar
There is a drain plug in the tank. I suggest not removing the plug. There is usually a build up around the threads on the drain bolt and when you remove the bolt from the tank, it tends to strip the threads and leak. I have had 2 of the 4 tanks that I drained to leak around the threads. From now on I pull the tank and give it a good cleaning. If it has a lot of build up in the tank, it will look like rust. I have cleaned many tanks and there is no pitting or signs of rust in the tank when I got done.
If there is any rust to the tank, it will be on top of the tank. The pick ups get mud slung on top of the tank and that is where you can get some rust holes in the tank. 4Runners tanks tend to be better protected and don't have rust holes on the top of the tank. Sounds like this truck is rust free so you probably wont have any problems on top of the tank;
When I do any tank work, I remove the bolts on the passenger side and loosen the bolts on the drivers side and tilt the bed. Trying to drop the tank is difficult as there is not much slack in the fuel lines.
If it was me, I would grab a U-haul dolly and tow it home. Sounds like you got a good deal on it. I would start with rebuilding the front end, shocks, fluids, tune up, shocks, brakes,and then start working on the creature comforts such as the ventilation system, giving it a good cleaning such as the carpet. It can take quite a bit of effort to get one back into shape but you have an easy truck to work on. Looking forward to seeing you getting it back on the road.
Old Jul 28, 2016 | 08:30 PM
coolfool's Avatar
terrys87 ty for the tip!! Iim not sure what to do lol. I have replaced 2 fuel tanks so far one on a Honda crx and the other on a current daily driver my 89 civic si and i said i wouldn't do another ever. So what im now thinking is siphon the gas tank and see with sum a siphon pump hopping there's not anti siphon tec on this year of a truck. do you think that would be ok ? If i see alot of evident rust in tank then ill have to do what you said.
Old Jul 28, 2016 | 08:35 PM
coolfool's Avatar
o ps as far as a u-haul dolly goes my only current transport is a 89 civic si so that's a no. So far best offer i have gotten is $250 for a guy on Craigslist . my nabor can do it aswell may be cheaper since she wants to visit family like 45 min away but that's only if i can work out the pickup times to be in her favor not sure what they would charge but less than 250 and even 250 seems fair round trip would be close to 500 miles
Old Dec 31, 2016 | 08:55 AM
coolfool's Avatar
this truck has been a major pain in the but had to fight with the auction a lot the paperwork they gave me would not work to get a insured are title so it took me until now to get my the proper paperwork.
im heeding to https://www.lkqpickyourpart.com/loca...t_-_Greer-213/ there is a 40% off sale tomorrow at all locations
i only see that there was a 1990 truck there not sure if theirs any parts left been there over a month
if its still there will the door panel bench seat as well as carpet doors be the same?
i need new rims and tires i see there are lots that will fit that's the mane reason for going what would you guys suggest for a factory 14-16 rims and tires to look for sine i need tires as well im going to look for a good set of tires and rims any suggestion?
Old Dec 31, 2016 | 09:07 AM
coolfool's Avatar
14 to 15 inch rims
Old Jan 13, 2017 | 10:55 PM
92 Toyo's Avatar
I put American racing 901s on my Toyota, they come in 17.5 x 8.5 though, so unless you can clear big tires there won't be a lot of sidewall. What kind of look are you going for? 5 spoke mags in aluminum would look cool. I'm sure you could find some nice 15x8s on craigs. Bolt pattern is 5x114.3 for all years of the pre taco 2wd? But you can get away with 5x4.5s and that gives you options for used jeep tires that people sell for cheap.
Old Jan 14, 2017 | 03:40 AM
Terrys87's Avatar
Ford Ranger Rims will interchange. I forget what size I installed on my 2 wheel drive and they may come in both sizes.
Old Jan 14, 2017 | 10:07 AM
Nervo19's Avatar
Last time I rented a dolly, about 6 years ago they were only $20/day. You can also rent one of their smaller trucks or pick ups for about $20/day plus mileage. So rent truck and trailer. At any rate you probably got a deal. If the gas tank was full when parked the gas might not be bad because no oxygen got to it. I can't tell if it needs body work but several people on here have taken a faded red truck and polished it back to beautiful. The red is single stage paint so if you polish off the dead top layer it will come back.
Old Jan 14, 2017 | 10:14 AM
Nervo19's Avatar
You got a steal. I'd look for 15" wheels for more truck tire options.
Old Jan 14, 2017 | 01:11 PM
dropzone's Avatar
Fossilized
that sucks about the paperwork. seems they would have done stuff a few thousand times before and had their act together.
There is truck similar to yours I see every now and than with the Ranger 2WD alloy rims that looks pretty decent
Old Jan 19, 2017 | 09:09 PM
coolfool's Avatar
i ended up going to the pull it yard that day and boy was it went threw lol . The only thing i got was sum carpet for the cab gonna Clean it up haven't installed it yet because need to clean it as well as i need ether a new bench seat or id prefer bucket seats that i i wouldn't have to modify. been looking alot on the forums and such seems i can use mustang rims ford ranger jeep rims and a few others. as for the gas it looked so nasty i wouldn't even put it in a cheap push lawn mower !
yes this was a nightmare to deal with the paperwork before i bid i asked a bought it and they stated never had a problem for 30 years guess who got to be the lucky guy!!!! but on a positive note that police chief was i guess voted out any way and new one says any he sells will just have a title rather than a seized vehicle paperwork sice he had to deal with me for 2 months dealing with this to correct it.
Lewis
Feb 21, 2016 01:45 AM
Oskr MorĂ¡n
Feb 11, 2016 04:46 PM
Damiandominguez
Jan 28, 2016 01:58 AM
springer91
Aug 13, 2002 01:30 PM
Paul S
Jun 20, 2002 05:07 PM
