Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old May 8, 2010 | 11:54 PM
  #861
grant526's Avatar
Originally Posted by slacker
might be flying by then and using "garbage" in the flux capacitor
Ya, When does the garbage buring flux capacitor go in anyway? I seem to have missed it in the build thread. . .
Looking Great!! Can't wait to see the finished Truck.
Old May 9, 2010 | 07:31 PM
  #862
slacker's Avatar
not for a few years yet
  #863
slacker's Avatar
buttoned up the Power steering lines today .. but found my return line just a few inches to short .. I'll have to replace that !!
originally , there was /is a bracket for the Main power wire for the starter , housed in a white plastic surround , just around the face of the oil pan ... I wanted to keep it , so I made up a new bracket for the wire casing to "clip" to .. as well as a support for the P/steering line
Old May 10, 2010 | 04:29 PM
  #864
slacker's Avatar
pic I forgot to post ...
anyway , the last thing i had to do before the inner paint .. was the new windshield washer nozzles ..
now located on the hood ..
holes cut
and nozzles installed
I also finished the underside , I made the holes for 3 washer hose clips ..
and thats it for now ... deliverd for some color
Old May 11, 2010 | 04:40 PM
  #865
slacker's Avatar
not much to add ..
couple of little things .. + got the P/S return line replaced ..
Old May 14, 2010 | 04:34 PM
  #866
slacker's Avatar
so a little bit today ... now that the cab is in the paint shop .. I needed to paint some pieces myself..
satin black
Old May 15, 2010 | 04:25 PM
  #867
slacker's Avatar
and the dash bezzles
same satin black
Old May 20, 2010 | 12:02 PM
  #868
HuKiT's Avatar
Almost been a week when do you pick up the cab? I bet your getting so pumped to start driving this baby~
Old May 20, 2010 | 03:47 PM
  #869
slacker's Avatar
yes ... way .
I checked in on the paint today .. and it will be " hi-build" primered tomorrow and then inners will be colored next week I hope ..
Old May 20, 2010 | 04:21 PM
  #870
morena67's Avatar
...wooooha...!
Old May 20, 2010 | 05:03 PM
  #871
slacker's Avatar
Old May 22, 2010 | 12:22 AM
  #872
annoyingrob's Avatar
What are you running for washer nozzles? I highly recommend trying out a set of 06+ camry nozzles, with that weird design that causes the fluid to just come out in a big fan. I run a set on my Supra, they almost drop in, and they're awesome.
Old May 22, 2010 | 03:34 PM
  #873
slacker's Avatar
just went with the 84-88 style ..
will the Camry one fit in the same hole ?
some work on the truck today ..
tightening bolts , and re-checking everything .. and prepping for the cab to go on for the last time
Old May 23, 2010 | 03:45 PM
  #874
slacker's Avatar
so a little bit more today ...
got the alignment done , and locked down .. steering damper is also now attached ..
replaced the spark plugs with a heat range lower and platenum tipped ($80.00 bucks) and also a lower temp 170* gates # 33867 thermo .
front drive shaft is now in the works ..
some cleaning and POR15 in the works ...
on the front part of the drvshaft .. under the u-joint , there is a plug ... I have misplaced the size /part #
anyone know it ?
Old May 24, 2010 | 04:10 PM
  #875
slacker's Avatar
got everything back together today . I checked some of the aftermarket stores today, for the dish style frost plug and had no luck , most wern't open today because it was a holiday , so I ended up taking the plug out of an old shaft I had from another truck that I parted out ... I "miked" it .. and was 34.25MM .. if anyone is ever interested..
anyway .. I install the plug , and cleaned and washed and prepped for the POR15 coating ...
Chassis is now complete .. (once I bolt on the front shaft) ... only thing left to do is the Gear oil ...
everything is done and ready for the cab
Old May 25, 2010 | 05:45 PM
  #876
slacker's Avatar
so crap ... checked in with the painter today .. and it was NOT primered on friday
just finishing up some of the "lines" .. so hopefully THIS friday we should see some primer ...
Old May 27, 2010 | 04:48 PM
  #877
slacker's Avatar
ALL gear oils changed today ...
also picked up the locks .. ALL were re-key'd to match ..
i'm ready for the cab !!
Old May 27, 2010 | 05:24 PM
  #878
dunnarunner's Avatar
It is a real pain when you have a schedule, and every thing else in go slow gear. Waiting for things to turn up and so on. I feel your frustration. I have just painted my doors and now I am waiting for the new chrome door handles to come, and the new door rubbers. and they are only 1500Klm away and it has been almost 2 weeks now. But what can you do?
Old May 28, 2010 | 08:58 PM
  #879
slacker's Avatar
yeah .. I do still have lots to do .. so I'm continuing on ...
Old May 28, 2010 | 09:00 PM
  #880
slacker's Avatar
worked on the rear door today while my boy was at ball practice ... no I'm not coaching this year!!
fit the new inner cover .. and also glued the rear door skin back on to the frame ..
also painted the shifters .. ;D
cab should have been primed today .. I guess I'll see on Monday
