Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old Jul 23, 2009 | 11:40 AM
  #581
grant526's Avatar
ROFLMAO!!!! I love it when Canadians mock us, from the states! lol
Have you heard Jim Carries bit about this?
Old Jul 23, 2009 | 11:41 AM
  #582
grant526's Avatar
BTW Nice Job on the Truck!! It's really coming along NICELY!!!! I Wish I had one like it!! : )
Old Jul 26, 2009 | 03:52 PM
  #583
slacker's Avatar
so it finally "cooled" down to 33* C (90*F) outside ... and was able to get some work done ..
as mentioned .. I decided to change the dash again .. so I welded up the clock , hazard, and dimmer hole .. and cut the NEW gauge holes .
the frame of the dash had also been butchered by the previous owner ..
so I cleaned it up , and started to make some new supports . I have more to do , to get the sterio supported .. but I wanted to make sure everything was going to be ok before I did all the work .
also , now had to RE-mount the heater controls
so , now I'm happy ....
and "installed"
Old Jul 26, 2009 | 04:00 PM
  #584
4banginRunner's Avatar
lookin good...now on to the real time consuming stuff.....tear down, paint, put it back together
Old Jul 26, 2009 | 04:19 PM
  #585
slacker's Avatar
Yep ... just about that time
Old Jul 26, 2009 | 04:37 PM
  #586
Justinvd's Avatar
Your my insperation
Old Jul 26, 2009 | 05:54 PM
  #587
slacker's Avatar
Originally Posted by Justinvd
Your my insperation
thanks Bro !!
now get to work !!!
Old Jul 26, 2009 | 06:59 PM
  #588
slacker's Avatar
Originally Posted by ocdropzone
whoooohooooo! nice my friend!
Thanks Robb ..
now this is a dash I can stare at all day !!! I'm finally happy with it
Old Jul 26, 2009 | 08:26 PM
  #589
TroutEhCuss's Avatar
I'm planning on having my dash customized by a pro in the town next door. I was a fool and destroyed a real gem of a dash - geez, I was stupid. I'm thinking good 'ol diamond plate dash.
Old Jul 26, 2009 | 09:23 PM
  #590
slacker's Avatar
ok ... best of luck there !
Old Aug 24, 2009 | 04:02 PM
  #591
Sushi's Avatar
For those of you who haven't seen this is person, it is truely well done (though I had no idea how much work went into it until I read this). I really like your "it was rusted.... so I made my own" attitude, something I definately share.
I can vouch for all the work with POR 15, it is the only rust paint I would consider using and it goes well with any surface, the rougher the better.
Did you use stainless for the hard brake lines? I used it for my lines, and it was much easier to work with than I had expected. I'll post up my build once I actually get to installing the fiberglass bed sides, which is taking alot longer than expected.... because once you find one spot of rust, soon the whole cab and engine are off.
Old Aug 24, 2009 | 05:49 PM
  #592
dannomite's Avatar
Bump for an update
Old Aug 25, 2009 | 04:28 PM
  #593
slacker's Avatar
thanks , and sorry .. no updates to speak of !!
I have been collecting a few parts .. but my summer has been to HOT , and busy to even consider working on my own junk .
soon the kids go back to school .. and relatives will go back home and I can then again get some "stuff" done to my own truck
no I didnt .. wanted to , but lordco said they couldnt supply it ? .. so I ended up using the "bulk" steel lines . I "zinc'd" them .. and will finish them when I pull the body off for the final welding and paint
Old Aug 25, 2009 | 05:04 PM
  #594
sethmcalister's Avatar
I've been following your thread since you started but haven't posted up yet. First, this is one of my favorite build ups on the forum due in part to your immense attention to detail. I commend you for that. I did want to comment on your idea of wood grain. You had said you were thinking about a tiger grain. Having worked in a woodworking shop, I think you should go with a tiger maple if you could get it. That would look great with a maybe a cherry stain for the color. Hope I'm not too late on the post.
Old Aug 26, 2009 | 04:13 PM
  #595
slacker's Avatar
Thanks for your comments Seth .. not to late .. and the tiger is most likely the way I'm going .. Thank you for your input !!
Old Aug 26, 2009 | 06:41 PM
  #596
toy93ota's Avatar
Just read through the entire thread, top notch work!
Old Aug 27, 2009 | 05:52 PM
  #597
slacker's Avatar
Thank you . wow .. seriously you read the whole thing ?
I have gone back .. to see my own progress and reading it took about 3-4 hours ..
getting to be a "book" now
anyway ..
I will have some progress soon
Old Aug 27, 2009 | 06:35 PM
  #598
dannomite's Avatar
Looking forward to it Mister Slacker.
Old Aug 28, 2009 | 04:59 PM
  #599
slacker's Avatar
ok .. so back to work ...
enough with the "holidays"
got the tranny tunel sealed ..
did some wrecker searching today and found just what I wanted ..
mock up
holes drilled and "Nut certed"
installed
Old Aug 28, 2009 | 05:15 PM
  #600
RMA's Avatar
RMA
Great job man .. Just now saw the video when you first started it , Nice Video skills .
Cant wait to see this thing finished Looking good though man
Good Luck !!
