Toyota Fiberglass: 1983 Trekker Build-Up Thread
#547
nope , bought a vid camera just for this
, but you gotta give me a wee bit of time .. engine bay looks a mess .. as I had torn into everything the find out what was wrong .. I want to "clean" it up a bit , and get everything in it's place .
#548
rewired the /98 MAF today .
and a VID
wee bit of belt squeek , but i'll get to that later .
http://s76.photobucket.com/albums/j2...PICT0001-1.mp4
and a VID
#549
I´ve been seeing your thread for 2 days now
... I have a stock 22r 4wd 86 pick up/ Bf´s Goodrich 30x 10 all terrain that I love, And because of my lack of knoledge and the dificulties of finding what I need down here in Acapulco (Mexico)
... I´m able to do only little things to improve my truck, but I love to work on her... I´m certanly learning a lot from all you guys...Congrats Man you are a true example of what it takes...
#556
ahh yeah right !!!! no rushing anything here , i'll just take my sweet time !
(hence the name)
little work on the dash today .. got the clutch start switch and "spare" switch cover mounted on the left side ..
had to cut out the old dash piece , make a new "cluster" mount and suport piece for the underside .. welded it all in , and got the dash partially back together
(hence the name) little work on the dash today .. got the clutch start switch and "spare" switch cover mounted on the left side ..
#557
so continuing working on the wiring , and getting the dash all layd out ..
continuing on the dash
got some of the swithches in ..
lamp reostat , hazard switch , and clock ..
started working on the heater bezzle and broke it .. D@#B !!!! so I now need to find another one
#559
ratz ... I still need to find one !
so .. looking at the pics this morning , the guage cluster looked "off"
I guess from my pulling it in and out of the truck with the suports cut out , bent it . the whole left lower section was "bent" over about 1/2 inch . once its bolted in the truck , should be good . but I had to bend it back into position ... I'll have to be more carefull !
Woohhoo! Now get that vid up!
