Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
need engine replaced
Old Aug 16, 2011 | 04:55 AM
chizzlebuns's Avatar
22re is pushing it for me and I wanted to find someone to swap another 22re in it for me, anybody know any good recommended shops?? I'm in bonney lake, Washington
Old Aug 17, 2011 | 10:53 AM
87 'runner boosted's Avatar
YOURE GARAGE!!!! really a simple engine to swap out man, for real, just did my first one. Course, I completely overhauled mine which took a little extra time, but they are REALLY easy to swap out. Youll find more than enough help online here if you need anything too...course, I understand if its not feasible to do so, just thought I'd mention it.
Old Oct 12, 2011 | 09:31 AM
Don't exactly have time. Unless I do it on the weekend I'm just worried ill screw up all the vacuum lines and electrical, since I have never done an engine swap. You think a beginner can do it in a weekend?
Old Oct 12, 2011 | 09:48 AM
CitrusTheDragon's Avatar
Throw a word out to the buddies on here and see if someone in your area that might have done it before can help and get the all data sheets or the manual on your truck just in case, plus there are a ton of members here if you run into a problem.
My brother-in-law and I are doing mine right now and it's my first full engine swap. Way easier then it seems, I would get a roll of vac line and replace any worn parts as you go, take the money you would spend at a shop(1500-2000 plus engine) and put it back into your rig. You can build a bad 22re with help off here and EB for about 3000 and drop it in over a weekend
Old Oct 12, 2011 | 10:11 AM
ya, you will find all the help you ever needed on here man...the electrical really isnt that big of a deal...vacuum lines were my biggest mishap. I deleted the egr on mine though and that did away with a TON of the vacuum lines. Weekend job??? meh...shouldnt be too hard. I had a 3" body lift on mine which really made it easy to access the trans bolts and what not...but ya, id say a solid weekend you could do it for sure.
Old Oct 12, 2011 | 10:34 AM
S&J Engines's Avatar
22RE Replacement/Swap
Greetings,
Kyle here at S&J Engines. Give me a call or shoot me an email if you'd like help getting a solid engine for your rig.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
