wiper fluid light wont go off...
Old 12-03-2008, 03:31 PM
idodgimus's Avatar
Hi all...
I've a 3rd Gen Ltd 4Runner and the wiper fluid light has been on for a week or so now... I filled up today, but only with a few ounces as it was pretty full to begin with!!!
i know its not urgent but it is annoying... any thoughts on what might be causing it?
Old 12-03-2008, 04:01 PM
Yukon's Avatar
Theres a wiper fluid light?
Old 12-03-2008, 04:07 PM
idodgimus's Avatar
i hope so, otherwise i'm ignoring some other problem that might need attention!!!
Old 12-03-2008, 04:10 PM
Yukon's Avatar
Take a picture?
Old 12-03-2008, 04:11 PM
toyota4x4907's Avatar
are you...are you pulling our leg?.....what does the light look like?
Old 12-03-2008, 04:41 PM
idodgimus's Avatar
it looks like the one in the top left corner, like a spray on the windshield
Old 12-03-2008, 04:53 PM
Yukon's Avatar
Well I didn't believe it so i went and looked in my manual, and there is a light like that, and it is to add windshield wiper fluid.
I guess mine doesn't work because I don't remember it being on when i was out.
Old 12-03-2008, 09:13 PM
X-AWDriver's Avatar
I guess I've never an mine out but I do knwo the rear sprayer will stop working when you get low but the fronts will still work for a bit.
Old 12-03-2008, 09:42 PM
NunRacer's Avatar
I think only the canadian 4Runners have this light.
I also had this problem and the dealership wanted $80 for the switch plus labor. What I did to fix this is pull out the switch from the bottom of the washer fluid tank (switch looks like a plastic pole with a white donut floater around it) and wrapped a strip of styrofoam around the floater. You can attach the styrofoam with a small elastic or fishing line.
Old 12-03-2008, 11:05 PM
idodgimus's Avatar
so i um... used the wipers - with a squirt of fluid - and the light went off!!!
peculiar, but fixed!
Old 12-03-2008, 11:16 PM
maybe it was too full...?
Old 12-04-2008, 08:02 AM
Yukon's Avatar
Well , if the canuck ones have it, I want it on mine. Anyone know anything about this
Old 05-30-2010, 08:49 PM
rookie.miller's Avatar
I see it's been awhile since anyone posted anything but my 98 4Runner has done the same thing recently. The light came on, I filled it up and it still won't turn off. I've tried spraying and it works fine but the light is still on. Any advice?
okamikai
04-30-2018 10:19 PM
ghostmoney
01-28-2018 11:42 AM
fountain
12-31-2015 06:08 AM
AkitaDog
09-01-2015 08:05 AM
msane99
07-17-2015 10:13 AM
Quick Reply: wiper fluid light wont go off...
