Will new shocks give me a lift?
Old Sep 24, 2004 | 02:51 PM
mummer43's Avatar
I have a TRD with the Bilstein shocks. My question is this: Are there other models of Bilsteins I could put on that are better that would not require a lift?
I was looking at the 5100 series. Will these fit on my truck?
Old Sep 24, 2004 | 03:01 PM
Robinhood150's Avatar
Shocks do not give lift. Their job is to slow down motion.
Old Sep 24, 2004 | 03:03 PM
I think you need bigger springs/coils or spacers
Old Sep 24, 2004 | 03:32 PM
User 051420's Avatar
RE-READ his question.......
Old Sep 24, 2004 | 05:22 PM
Adam F's Avatar
Your thread title and question is kinda confusing :pat:
There are a bunch of different lengths in the Bilstein 5100 series. Call a retailer or Bilstein themselves and tell them what your setup is and they will reccomend the proper length.
Old Sep 24, 2004 | 06:21 PM
sorry i misread! and I don't know. Can't say if the 5100 series will fit a Tacoma though (not listed on their website)
Old Sep 24, 2004 | 06:32 PM
mummer43's Avatar
You're right it is kind of confusing... sorry.
What I meant was can I put a longer shock on without a lift kit. The result being a small amount of lift.
It looks like the 5100's are for the rear and I would need coilovers for the front. Is this correct?
Old Sep 24, 2004 | 06:35 PM
humanoid's Avatar
Ummmm, you might not have enough downtravel when you rebound from going over bumps.... but I could be wrong.
Old Sep 24, 2004 | 06:38 PM
cubuff4runner's Avatar
Coilovers are a sleeve which goes over your strut that your spring sits on. The sleeve is threaded with a big arse nut that the spring sets on so you can adjust the height.
The front is struts - rear is shocks
Old Sep 24, 2004 | 07:33 PM
mummer43's Avatar
Ok, thanks... I'm learning here.
Old Sep 25, 2004 | 07:52 AM
mummer43's Avatar
So how do King coilovers on the front and Bils. 5100's on the back sound?
Old Sep 25, 2004 | 08:16 AM
This may be of interest to you:
https://www.yotatech.com/forums/showthread.php?t=41353
Old Sep 25, 2004 | 08:37 AM
mummer43's Avatar
Originally Posted by gapguy
You mentioned that you have a heavy bumper and this is why you cranked them so high. Without a heavy bumper, I'm assuming I can achieve some lift without having to crank them so high?
This guy added Kings and they gave his truck about 2" of lift in the front:
http://www.parksoffroad.com/tacoma%2...g%20shocks.htm
Old Sep 25, 2004 | 08:42 AM
The SAW's are adjustable from 0-3" with a bumper or not. So yes, you can easily achieve lift without cranking them very high. And yes you could leave them at stock height. You'd likely crank them only an inch or so. The Taco even weighs less. My guess would be that these would be much softer if there wasn't much cranking involve. As soft as the 675lb springs would allow.
The best thing about coilovers is that you eliminiate the need of a coil compressor to change the configuration!
Old Oct 1, 2004 | 07:46 PM
mummer43's Avatar
Can you crank them while they are installed?
Old Oct 2, 2004 | 11:58 AM
humanoid's Avatar
I believe that you can, but I may be wrong because I'm too poor to have coilovers.
Blamalam
Mar 12, 2022 07:34 AM
okamikai
Apr 30, 2018 10:19 PM
Sep 4, 2015 09:27 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
SMOD
Jul 27, 2015 01:45 PM
