wierd problem with the gears
Old Sep 18, 2004 | 05:43 PM
northfacer581's Avatar
i just got my lift, shocks, and new tires done yesterday and couldnt be more pleased. i went pretty hard wheeling in it all day today; got stuck in water that came up to the doors but it was ok because my friends 04 trd off road package tacoma pulled me right out. on the way home, and after i cleaned it all off, when i would hit speeds where the gears should change, the rpm's would sort of "hover" around 2200 or so and then go back down, changing to the next gear. my 4runner is automatic, and even when i drive so that i let off the accelerator as to let the gears change, it still "hovers". any help would be greatly appreciated.
Old Sep 19, 2004 | 04:10 PM
colsoncj's Avatar
Pull the tranny dipstick and see if there is any water on it...
Old Sep 19, 2004 | 04:53 PM
jimbo74's Avatar
sounds like you either messed up a sensor for the transmission or got water in one of the gearboxes and its effecting the drivetrain
Old Sep 19, 2004 | 09:41 PM
AgRunner06's Avatar
That's what I would guess. A tranny flush is probably in order. I wouldn't drive it too much with water in there. That could be a VERY costly mistake. Make sure you extend your tranny breather next time.
Old Sep 20, 2004 | 05:05 AM
934rnr's Avatar
Yup I learned that lesson a while ago with another vehicle. Water in a Auto transmission destroys the transmission clutch packs very quickly after you start to feel weird things happening with the transmission it's already too late.
I doubt that's the problem.
It sounds like a sensor connector got wet though. I would unplug all connectors that lead to the transmission spray them out with electrical contact cleaner if you find other areas that got wet unplug one connector at a time and clean them. Reassemble and see if it goes away.
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
