wheelers wheels on backorder. replacement suggestions?
Old Feb 16, 2006 | 06:38 AM
lee's Avatar
lee
nice choice.. rims will look great!
Old Feb 16, 2006 | 06:46 AM
bflooks's Avatar
heath had photchopped them onto my truck for me. the thing is going to be bad ass!
Old Feb 16, 2006 | 07:54 AM
BajaRunner's Avatar
I dont know why anyone doesn't do this, but, just turn your wheels over to a side and inspect how much clearance you have between the caliper and the inside of the wheel.
Mine came with ABS and 16", with my 16" black steelies I have about .75" of clearance around the calipers. I wouldn't be able to fit any 15" rims most likely.
It only takes 5 seconds and no one ever seems to think of this?!
Old Feb 16, 2006 | 10:17 AM
E-money's Avatar
Are you going with the 16x8 or the 16x 10?
Old Feb 16, 2006 | 10:40 AM
  #25
bflooks's Avatar
16x8's with 3.75" bs.
Old Feb 16, 2006 | 12:56 PM
  #26
BOSTON4RUNNER's Avatar
I concur, was wondering if you are going with a full size roof mounted spare or similar set up? maybe of the rear bumper maybe?
Old Feb 16, 2006 | 02:33 PM
  #27
bflooks's Avatar
i am getting a retreaded spare in the 285/75/16. drew (shotking) found a link for some, and they are only about $95 delivered. perfect for a spare.
and for the location, i have no idea yet. hopefully there is room underneat for it. if not, then i am thinking about asking eric to custom make some sort of mount using the existing rack.
Old Feb 16, 2006 | 03:03 PM
  #28
lee's Avatar
lee
you can just deflate it and put it underneath.
do not use the existing rack for a tire, it wont hold it.. those crossbars are REALLY weak plastic.
Old Feb 16, 2006 | 04:32 PM
  #29
bflooks's Avatar
the cross bars, yes. but the rails should be strong enough to hold, no? can't it hold up to 175lbs?
Old Feb 16, 2006 | 04:38 PM
  #30
even deflated, undeneath the truck,,,,makes it difficult for access perhaps in an off road situation, also clearance problems when off roading could occur
I would go custom rack, on the roof or something
I have my full size spare in the back of my truck inside the tailgate, simple but works, maybe do something like that with a hold down or something
Old Feb 16, 2006 | 04:39 PM
  #31
I would think stepping up to some type of safari rack might be good,,,,if you like that look, does prove useful for traveling with a full size spare or two
as for a spare, I bet that is fine a retread, however pepboys have semi aggressive off road tires in that same size for 100 bucks,,,I priced them out as that is what I am going to run once I do my body lift and spring time modifcation spree
Old Feb 22, 2006 | 10:31 AM
  #32
lee's Avatar
lee
they bent really easily when i was playing with them for my surco rack.
i wouldnt trust my tire or the life of the person behind me to the strength of plastic stock crossbars.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
