Wheel Question
Wheel Question
I tried these wheels on a 96 4 cylinder tacoma today, but they do not fit. I'm not at all familiar with toyotas past 1994, but I know these wheels came from this generation of tacoma. Is there is a difference between the 4 cylinder and V6 steering and suspension?
Something is for sure wrong !!
Question is is it your Hub or is the wheel bent.
You could not get the wheel to seat on your hub??
It did not pull on as you got all the lugs nuts on so the shanks could center the wheel??
I own the wheels and was looking to sell them to the owner of the Tacoma. The wheels are not bent, we tried two wheels on his passenger side steer axle and got the same result both times. We didn't try putting the lug nuts on as it was obvious that there was an issue. And yes, the wheel would no seat on the hub and was getting very close to the calliper as well.
Not sure what you are asking me about measuring, but we didn't measure anything. The guy had recently bought the truck I believe, but it looked unmodified to me. He had unmatching 31" tires on unmatching steel wheels.
The owner has found a different set that fit, but before he came over, he mentioned having difficulty finding wheels that fit and I basically guaranteed him they would work so I felt bad when he drove away without them.
So, it may be the 2wd prior to the Pre-Runner and the 4wd did not share the same hubs thus the fitment issues Brendan encountered. Yes?
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
