What size bushings for 4Runner sway bar end links.
Old Jul 27, 2009 | 12:56 PM
noahrexion's Avatar
For the record, these are what I was talking about. They are indeed polyurethane and will hold up a HELL of a lot better. If you drive pavement a lot you will surely appreciate the immediate improvement these will provide.
@ $9.99 and 30 minutes its really a no brainer.
Old Jul 27, 2009 | 01:28 PM
Bobs4Runner's Avatar
noahrexion, where can I get those. I need front and rear ones. I've been looking all over.
bob
Old Jul 27, 2009 | 01:32 PM
Godzilla's Avatar
bob
Please at least read the full thread. There is a link to an existing thread with the ES part number and noah even mentioned where he got them from.
Old Jul 27, 2009 | 01:38 PM
xcmountain80's Avatar
Originally Posted by Rock Slide
Aaron, how about a photo to help clear things up
What for? the obliviousness is far more fun, I'm on it after the dog park.
Aaron
Old Jul 27, 2009 | 01:52 PM
  #25
Ok the end links or links according to Toyota. So as previously stated the END LINK bushing is what I'm curious about. The entire thing OE will run you $74 ea. from Toyota. All I need is the bushings and the red ones in one of the previous posts should work.
The overall (difficult to get a good read) measurement of the bushing (lower one) is 30mm +/-.
Aaron
Old Jul 27, 2009 | 02:00 PM
  #26
Godzilla's Avatar
Yup then you want the 3/8 ID bushings from ES pt # 9.8105
https://www.yotatech.com/forums/f2/i...ushing-105193/
http://www.energysuspension.com/pages/endl.html
Old Jul 27, 2009 | 02:55 PM
  #27
Yea I win again! I'll see if I can get these ordered asap.
Aaron
Old Jul 27, 2009 | 03:09 PM
  #28
noahrexion's Avatar
lol, i said that in my first post I guess sometimes it just takes 2 pages of posts
Aaron, you will be very happy with these. Even new OEM bushings don't compare. Be sure to give them a good greasing before/during install!
Old Jul 27, 2009 | 06:24 PM
  #29
Godzilla's Avatar
Yup, post #7 was the winner
Old Jul 31, 2009 | 07:18 AM
  #30
Got the parts, just gotta install them now. What grease did you all use? I was told to use 100% silicone grease, anything else will eat them up. Also is there a certain torque # to use on the end-link bolts?
Thanks
Bob
Old Jul 31, 2009 | 07:29 AM
  #31
4Crawler's Avatar
Thanks
Bob
For rubber, yes on silicone grease. For poly urethane, most anything works fine, I usually use a graphite loaded wheel bearing grease on mine. And on the bolt torque, no specific value, rather you want to tighten the nut until the bushing just starts to compress and that is plenty.
Old Jul 31, 2009 | 08:18 AM
  #32
Roger that!
Aaron
Old Jul 31, 2009 | 11:58 AM
  #33
The Ruckus's Avatar
so I should probably back mine off a bit. I just tightened the left side to match what the right side looked like; the bushings look like and endlink s'more.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Whatever123
Sep 30, 2015 12:12 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
