what shocks for LC/Tundra lift?
Old Jul 16, 2006 | 07:45 PM
jla123's Avatar
I know OME, just seeing if there is anything else, they are quite pricey. I have recently purchased Tundra and LC coils, so need to get new shocks. I was looking at the Sonoran Steel lift and they are using Tokico shocks for a 4runner or Taco. Any suggestions????? thanks
Old Jul 17, 2006 | 01:33 AM
rocket's Avatar
yeah, search and read a lot.
Get the same shocks that S.S. offers or Bilstiens. You don't want OME with those springs.
Old Jul 17, 2006 | 06:50 AM
jla123's Avatar
i have searched and read alot of posts. most people seem to be using OME, just thinking there was an alternative.
Old Jul 17, 2006 | 06:55 AM
MTL_4runner's Avatar
The OME's are basically a LC shock (at least that was their intended use, 4runners and tacos adopted them later).
Might want to PM Andy (Bamachem) for other possible combos.
Old Jul 17, 2006 | 07:33 AM
emptypockets's Avatar
You'll most likely want to use stock Toyota LC shocks with the LC springs. They're the correct longer length and will exactly match the articulation of your LC springs. The parts number is: 48531-69486. They're cheap too, $54.20 per pair from Toyotapartssales.com. BTW: they're stock Tokico black. Hope that helps!
Old Jul 17, 2006 | 12:31 PM
jla123's Avatar
thanks alot for the info, i appreciate it. so if I get those black Tokicos for the LC coils, should i look for shocks that are for a Tundra? thanks again
Old Jul 17, 2006 | 01:28 PM
According to my information, Tundra coils go on the front and LC coils on the rear.
Old Jul 17, 2006 | 01:59 PM
UNR.Grad's Avatar
All the info you could ever need thanks to Bama, recently updated.
Old Jul 17, 2006 | 02:06 PM
Strap22's Avatar
Sponsoring Vendor
We sell alot of OME shocks with LC coils and have had no complaints. Steve is the authority on 3rd Gen setups and he will know which one to use but my customers are happy with the OME shocks. Just my 2 cents.
Old Jul 17, 2006 | 02:47 PM
rocket's Avatar
sorry, i should have been more specific. According to Steve, front OME shocks are bad news. Understandably so, they are fine for the rear.
Originally Posted by sschaefer3
Well I know why everyone is pulling apart axles with the longer Old Man Emu front shocks.
Droop of the arms on a 100% stock TRD Tacoma with the longer TRD shocks is 15 degrees. Droop on this 4RUnner which has the limiting straps set more conservative that I did on mine is at 24 degrees.
Well DUH. That too much droop. I would say 20 max, if Toyota's engineers went 15 on the TRD and I would imagine the stock 4Runner shocks go 10 degrees.
IFS does not kill parts, too much droop does.
Originally Posted by Crux
Heh, which explains why it was such a pita to get those shocks (OME) installed in the first place. Oh well, guess I got the limiting straps for the time being.
Old Jul 17, 2006 | 02:53 PM
Strap22's Avatar
Sponsoring Vendor
Thank you for clarifying that. I just wanted to make sure he didn't think OME's sucked. Thanks...........
Old Jul 17, 2006 | 03:44 PM
jla123's Avatar
Thank you all very much. I am good to go.
Old Jul 20, 2006 | 05:17 AM
sschaefer3's Avatar
They are nice shocks, big pistions and sized for a Prado. Which is too long for a 4Runner. I blew one alxe, Andy blew BOTH axles, at the same time, one right after the other.
Front shock length is very critical. Also you can't just "throw" FZJ-80 shocks on a 4Runner and expect them to work. The compressed length is too long you will squish the guts out from over compression and there are a slew of other issues that our kit addresses for the added droop. which is signifigant.
ARB/OME makes nice stuff. They just re-used Prado stuff for the 96-02 4Runner, which is OK, but not ideal. Although the studs on the upper rear N86 shocks do break off on alot of people. All of whom have no Trac/PanHard correction. Which is more than likely the culprit not the shock.
Our FJ-62 has all OME stuff, 2K worth. My 3rd Gen SAS's have OME rear shackles, main eye center pins & OME FJ steering stabalizers. They have good stuff and I use it if applicable.
I do however think Alcan and Deaver have the leafs down better.
justdifferentials
Just Differentials
Sep 8, 2015 03:15 PM
justdifferentials
Sep 8, 2015 03:13 PM
mistershmi
Aug 31, 2015 03:44 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
