What mods work w/ the supercharger?
Old May 22, 2003 | 12:18 PM
broknlgs24's Avatar
Question What mods work w/ the supercharger?
i own a S/C 2001 4Runner. I have the TRD exhaust and an Amsoil Air Filter. I've also done the elbow removal mod. Besides adding Headers, what other mods will work well w/ my setup (ie. ISR mod, deckplate, ECU, Free FMU, etc.)?
Old May 22, 2003 | 12:49 PM
tomstin's Avatar
Set aside some time and search on supercharger in this forum. I think you will find that the ATF cooler is a requirement and the valve body upgrade is recommended if you have A/T. Take a look at gadget.com when you have a few hours to spend reading. If you ping, cooler plugs and thermostat seem to help. Then you need to start down the fuel modification path.
Old May 22, 2003 | 01:04 PM
broknlgs24's Avatar
i've spent a lot of time on Gadget's site. i've also recommended it to a lot of my friends. i was concerned more w/ the ISR mod, Free FMU mod, ECU mod, deckplate mod, etc. i guess what i was thinking was more along the lines of modifications as opposed to upgrades such as the A/T Transmission Cooler, valves, etc...
Old May 22, 2003 | 01:26 PM
pfdaxe's Avatar
The "free" fmu is listed in your s/c install manual. Forget the deckplate mod with a s/c unless you have the fuel mods. Just run the stock air box so you don't suffer from fuel starvation. You may also try the ECT mod listed in the tech forum to assist with ping.
Old May 22, 2003 | 08:00 PM
ssbogger's Avatar
Thats the great thing about the deckplate mod, you can just seal it off until you make the fuel mods!
Old May 23, 2003 | 06:43 AM
tomus1000's Avatar
Tomstin has given you some pretty good advise here. Follow it. There is TONS of information about the supercharger right here on Yotatech. Use the search function. It works quite well. That stuff alone should keep you busy for a while.
Old May 23, 2003 | 07:58 AM
broknlgs24's Avatar
can someone tell me if they've performed the ISR mod on a supercharged engine?
Old Jun 2, 2003 | 07:21 AM
broknlgs24's Avatar
anyone? will the ISR Mod work w/ the supercharger?
Old Jun 2, 2003 | 07:33 AM
SLC Punk's Avatar
I tried the ISR mod on my 4Runner. My results...
Nothing!! All it did was give me a really high pitched whistle.
Don't waste your time on the ISR if you have the S/C. My $0.02
Old Jun 2, 2003 | 12:52 PM
Bumpin' Yota's Avatar
.... You may also try the ECT mod listed in the tech forum to assist with ping.
HUH??? Doesnt' the ECT mod advance the timing? Don't most boosted or forced induction systems require retarted timing instead of advanced timing to prevent preignition and pinging??
Steve
justdifferentials
14
Jun 11, 2017 08:36 PM
anniesball
12
Sep 30, 2015 08:09 AM
Foage3z
Florida
Aug 31, 2015 04:49 PM
anniesball
Jul 29, 2015 11:46 AM
