What am i missing???
Old Sep 5, 2007 | 02:19 PM
apalmer1's Avatar
Im currently putting a centerforce clutch into my 04 taco (5VZ-FE, R150F) and for whatever reason i can not get the tranny to slide back.
Things i have removed/unbolted:
-5spd stick, and 4wd stick
-wiring harness
-front driveshaft
-rear driveshaft
-plumbing and slave cylinder
-bellhousing bolts, including the 2 bolts to the starter
-the 4 bolts on the engine side of the tranny, and the clutch cover they hold on.
Im using a small hydraulic table as a tranny jack and i have the transmision about as close to level as it could get, but after pushing and tugging and prying i cant get the damn thing to budge, i even tried letting the back end sag down a bit to loosen the front up.
Somebody who has done this before, what am i forgetting???
Old Sep 5, 2007 | 06:26 PM
Fo-runna's Avatar
Cross member?
Old Sep 5, 2007 | 07:01 PM
DeathCougar's Avatar
Did you take off the corssmember as Fo-runna said? You should have 4 12mm bolts holding the rubber mount to the cross memer, as well as 4 14mm bolts/nuts holding the cross member on.
Old Sep 5, 2007 | 09:38 PM
pennywize's Avatar
my guess is cross member...
TheBFA
Feb 15, 2020 06:55 AM
Badlander
Oct 10, 2015 08:05 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
voiddweller
Sep 28, 2015 11:21 PM
