weird starter problem
Old Apr 23, 2007 | 07:05 AM
mtnbkr's Avatar
The other day, my wife told me our 97 4Runner's starter was running on even after it cranked. It even kept running after removing the key, trying to crank the engine without input from her. She stopped it by putting the key in and "cranking" the engine again. I can't reproduce this problem, but twice it has either given me just a click (and then immediately started) or nothing at all (still started on 2nd try). The starter spins the engine as fast as ever. The battery is a year or two old. There's 142k on the odometer.
Is this be a simple contact issue or do I have another problem with the starter? The dealership says the starter needs to be replaced.
Chris
Old Apr 23, 2007 | 07:22 AM
rdlsz24's Avatar
I would start by replacing the contacts and then move onto replacing the starter if it comes to that.
Of course the stealership wants to sell you a new starter
Rob
Old Apr 24, 2007 | 05:52 AM
JETSI's Avatar
My 97 4Runner is doing the same thing. Guess i'll try replacing the contacts.
Old Apr 24, 2007 | 06:00 AM
mtnbkr's Avatar
I did some further reading and searching here and on the Internet. It appears the problem with the starter not disengaging is the plunger in the solenoid. That is a replaceable part as well. I'm going to order the contacts and the plunger and do the job myself.
Chris
Old Apr 24, 2007 | 06:21 AM
4Crawler's Avatar
Pull the starter out and give it a good going over:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Could be dried/dirty grease is causing it to stick on, could be unevenly worn contacts causing the same problem. How? Plunger hits the contacts with a ring (contacts 180 degrees apart) and if one contact is worn lower, that can cause the plunger to get "cocked" in the bore of the solenoid and get stuck.
Old Apr 24, 2007 | 10:19 AM
wizzells's Avatar
Ford's back in the late 80's, early 90's were infamous for this. Turn the key to start and the starter would just keep on goin. Pain in the ass. If I remember correctly it was the solenoid that had some bad contacts. I would start there like you mention reading about elsewhere.
Old Apr 24, 2007 | 10:47 AM
mtnbkr's Avatar
I went ahead and ordered the contacts and the plunger from the local dealership. I'd rather have the parts on hand and not need them than get halfway through a job and need parts that can't be had till the next day. Or worse, have to tear into it again...
Chris
Old May 6, 2007 | 12:53 PM
mtnbkr's Avatar
Finally got around to doing the job. It took less than an hour including cleanup. I didn't have to disconnect anything other than the starter and the battery. Very easy job!
I replaced the contact, the plunger, and the return spring. I probably did more than I needed to do, but I wanted to make sure I didn't repeat the job. One contact was very eroded, the plunger was worn, and the return spring was nearly a 1/4" shorter than it's replacement.
Since the problem was intermittent, I won't know if I was successful for at least a few days.
Chris
Old Nov 12, 2007 | 02:12 PM
Swede's Avatar
How much did they charge you for the parts?
Old Nov 12, 2007 | 02:16 PM
Whitey13's Avatar
Check his site...
Old Nov 12, 2007 | 02:48 PM
mtnbkr's Avatar
About $50 in parts, but I replaced everything that could cause my symptoms rather than risk having to do it again. No problems since...
Chris
Old Nov 13, 2007 | 09:13 AM
gpcollen1's Avatar
That is pretty quick. Did you not have to disconnect the swaybar??
Old Oct 12, 2012 | 12:32 PM
yprior's Avatar
A rebuilt starter for my 87 pickup cost less than $50 and I didn't have to spend the time
Hiluxtrucha
Jul 22, 2015 10:00 AM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
