Vasinvictor's 3.4 rear mount turbo setup
#121
Go to another shop then. I had my factory stall redone and it ended up around ~2800-3000. Could get it up to 3200 if I really stood on it.
#122
Congrats
Hey Drew, I had to create an account just to congratulate you on how far you've taken this beast! I've been rockin my rear mount for a while and have decided to go front mount with a CX racing header kit.
I'm going to be getting rid of most of my aluminum 2" charge pipes and replacing them with 2.5" charge pipes. I'll sell them to you for cheap if you want
#123
This isn't in regards to the turbo talk at all btw
#124
#126
What if I just want the cool "pshhhhhh" sound? lol seriously though I'll probably skip it. I do have a problem with the silicone adapter blowing off the throttle body if I don't carefully let the pedal back out. I don't like having to feather it. I'm using a silicone adapter on the TB, but a worm drive clamp. Maybe a t bar would work better. That compressor surge sounds pretty awesome too.
#127
#128
Sorry been in Colorado riding dirtbikes and now been trying to catch up on work and such. I might be interested. I've been hesitant to put alum on for various reasons but I realize it does look pretty bad as is. PM me what you have and what you want. I'm wanting to add a BOV too, if you happen to have a pipe with a fitting in it.
#130
You'll get the same power with less PSI guaranteed. 1.5" is great for boost gauge eye candy but 2" aluminum is perfect for rear mount setups to battle lag and heat since you aren't intercooled.
#131
Also I just got a couple new silicone adapters to replace a couple glued pvc 90s and repositioned my meth nozzles in front of the throttle body butterfly. Behind the butterfly the engine vacuum was sucking the prime out if the meth and making a big lag before meth kicked in. I hope by mount the nozzles on the other side, away from vacuum, this will fix that issue. Pics to come.
#132
I would rather have 2.0" tubing but I have a 1.5" body lift. The 1.5" PVC od is 1.9" and it was really tight in some places. Maybe I can crush the tubing in some areas. Where did you run your charge pipe and how much body lift?
And I'm glad you moved your nozzles back. Not only will that help with unnecessary suction but it will also better equally distribute the meth between the 6 intake channels. I've heard of outer piston failures because people had the nozzles too close and all the meth was getting sucked into the middle 2/4 channels and leaning out the outers.
#133
#134
You want the nozzle as far from the throttle body as possible. In your case you are limited by the MAF sensor. If you put it before the MAF it will screw the readings up real good.
If you were standalone and didn't have a MAF then I would run it right at the turbo outlet or even pre-turbo.
Also the PCV pipe has much thicker walls then aluminum. You should be able to fit 2" without much hassle, it can be crushed some without much work if needed.
#135
My luck ran out today. I changed plugs (every oil change now) and putting on the new couplers and repositioning the meth nozzles. I went on a cruise and tried my once-a-week WOT rip. Ignition misfire and then KABOOOOM a huge backfire thru the throttle body. Blew my throttle body coupler off and the FPR hose off. After I reconnected everything roadside I start it up and hear this...
http://vid300.photobucket.com/albums...l/IMG_6694.mp4
S%$#.
S%$#.
#137
I'm not sure. I drove it home 5 miles like this. It runs great idles good the clicks speed up with engine RPM but don't seem to get any louder.
Just goes to show you can be all kinds of careful and still something like this can happen from one stinking misfire.
#138
S%$#.
S%$#.
#139
The bottom end sounds fine. I hope it's as simple as a dropped valve or some heads off fix. What part of a bad valve would make that noise and it still run good?
What stinks is I preregistered for our local car show and burnout competition (on metal plates) is this Saturday. Such is life.
#140
Check each spark plug and the gap in the mean time. Never know
