Old Apr 6, 2016, 07:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Interior Guides
Print Wikipost
True Front Door Speaker Size?? (2002)
Old Mar 22, 2009 | 08:02 AM
wmflyfisher's Avatar
Hey guys,
I think its the same for 99-02 models but not sure. I'm looking to replace the front speakers and can't seem to find the true size of the front door speakers. I've read 5.25 and 6.5. I really want to go 6.75 so if anyone knows that would be great. Thanks in advance.
Old Mar 22, 2009 | 01:05 PM
DeathCougar's Avatar
6.5" is what i am finding with a quick search here on YT
Old Mar 22, 2009 | 01:17 PM
Thanks DC. Yeah thats what I've read too. Some sites say 5.25. Think I'll just order the 6.5's
Old Mar 22, 2009 | 02:12 PM
wizzells's Avatar
The ones I pulled out were a 5.25". I put some JBL 6.5" speakers in their place. I had to clearance the door itself in the area where the magnet fits into the door, modify the mount, and space them out so the magnet clears the window when it's down. I also trimmed the inside of the door panel itself where it fits over the speaker. If I hadn't, it would have hit and ruined the speaker when I reinstalled it. I would imagine the 6.75" speaker would fit with similar work.
Old Mar 23, 2009 | 02:43 PM
Jay204's Avatar
Pretty sure their 5.25 (factory).....but the door's will fit up till 6.5.
Old Mar 23, 2009 | 02:45 PM
Well like I said, its merely info I am finding through searching here on YT, through what other members have installed. I am not 100% as I do not own that Gen 4Runner anymore.
You could always take your door apart and measure before ordering
Old Mar 23, 2009 | 06:40 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I put 6.5" speakers in the front of my 99
Old Mar 23, 2009 | 07:47 PM
nieuwendyk-25's Avatar
They are an odd size that is close to 6.5" You have to make an adapter to fit in the factory mount. Below you can see how I did mine. I used Focal 6.5" components. I highly recommend them...I decided I did not need a Subwoofer after installing them...nice tight, low bass....I liked them so much, I modified my rear doors to hold 6.5" components also (they were originally 4")....but that's a whole other write up.
If you look close you can see the holes are slightly wider than a 6.5" speaker, but not as much as 6.75"
Old Mar 24, 2009 | 05:10 AM
Rock Slide's Avatar
I installed 6.5s in the front and 5.25s in the rear. Here's a write up thread on my door speaker install in case you missed it: https://www.yotatech.com/forums/f96/...nstall-116312/
Old Mar 24, 2009 | 10:47 AM
Hey Rockslide! What's up!
Thanks for posting that link...I was going to say I thought someone had made an adapter out of the old speaker, but I had forgotten it was you. Great pics...man your 4Runner door was cleaner inside than mine in your pics.
Great write-up!
Old Mar 24, 2009 | 10:53 AM
VSU_4runnin's Avatar
anyone replaed the little speakers there near the window, both of mine are shot, and i cant even figure out how to get the cover off..
Old Mar 24, 2009 | 11:04 AM
Rock Slide's Avatar
What's up w/ you Doc! Have not talked to you in a while either. Thanks for the comps too. . Love your 4Runner BTW...I've always liked red 4Runners. Just don't see many of them at all over here.
VSU, I replaced my tweets in that same link posted above...although I did not go into detail "how" I did it (forgot about that.) Anyway, the covers are easy to remove. I've always used a small flat head screwdriver to pry the plastic triangular covers off. Just take your time doing it and it should come off easily. The plastic rivet on the inside may break off if you do it too fast (friend of mine broke his cover when he tried prying it off too quickly.)
Old Mar 24, 2009 | 01:26 PM
idodgimus's Avatar
I put Alpine 6.5s in no problem... Mainly followed Rock Slide's guide, cut the carboard surround off the stock speaker (to leave the metal disc) and the Alpine's fit no problem at all. The black triangles just popped right off and the tweeters got wedged in with foam surrounds (come with the speakers)
here's the speakers product page, sound great and are well priced
Old Mar 25, 2009 | 06:21 AM
Great info guys!! I will use this as a guide to install my set!!
Old Mar 25, 2009 | 11:39 AM
tweeters, awesome thanks RS i know nothing of soundsystems, i can wire one, but i have no clue what is what
Old Mar 25, 2009 | 12:04 PM
Rock Slide's Avatar
No problem.
And just for grins, if either of your side mirrors become loose, you'll need to pop the same triangular speaker cover off again to access the 3 large bolt heads that hold the mirror in place. Had a buddy of mine's driver side mirror become loose (bolts were trying to come out by themselves) and he had no idea how to fix it. I showed him how easy it was to pop the cover off and tighten the bolts. And to think, he was about to take it to the dealer.... I just make fun of him now.
Old Mar 25, 2009 | 12:16 PM
So to confirm, the original speaker is a 6.75 correct?? Thanks for the metal ring tip. I'll probably do this. I have a nice set of components but REALLY don't want to deal with finding a place for the xovers, running the wires, and finding a place for the new tweeters so I've just decided to go with a premium set of coaxials. Should sound good with a good amp.
Old Mar 25, 2009 | 12:32 PM
idodgimus's Avatar
seriously, go check out the Alpine Type-S - the x-overs are real small and attached to the speaker wires and the tweeters fit perfectly under the black triangles, but come with a variety of mounting options in case that doest suit you.
They're really well priced and sound great to boot!
Old Mar 25, 2009 | 01:09 PM
nc994run's Avatar
Original size is 5.25" and you can fit 6.5" with minor modifications
jasonty
41
Dec 23, 2018 01:00 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
