TRD boost gauge accuracy / calibration????
Old May 3, 2004 | 12:10 PM
yoda-g2's Avatar
Question TRD boost gauge accuracy / calibration????
I just installed my boost gauge this weekend and it is only showing 5.5 - 6 lbs of boost at WOT. I was under the impression that the S/C should put out in the 7-8 lbs range. But I noticed that when I turn off my engine it reads "-1". I was wondering if the means that everthing will read 1 under where it should?? Because that puts me closer to the correct range. Any way, is there a way to recalibrate this thing??
Or is my charger (1st gen gray) not putting out the proper pressure... :cry:
Old May 3, 2004 | 12:45 PM
4RunnerFever's Avatar
I had the same issue and called TRD. 6psi is the max so you are good to go.
Old May 5, 2004 | 06:20 AM
sn0w_m0nkey's Avatar
yup 6psi on mine also. but you know my first boost gauge got stuck on +4, performaceproducts replaced it after i sent it back.
Old May 5, 2004 | 06:26 AM
96TRDsc's Avatar
mine goes to 7-8psi...what are you using for the boost source for the gauge? I'm t-ing off the port right off the sc that goes to the fpr.
Old May 5, 2004 | 12:04 PM
yoda-g2's Avatar
That's the same port I'm using.
Does anyone else's read -1 when the engine is turned off??
Old May 5, 2004 | 12:26 PM
96TRDsc's Avatar
check out my sig pic...my boost gauge is actually a hair over 0 but still in the white of the 0 marker...I will check today and try to get some pics of WOT and turned off.
Old May 5, 2004 | 12:36 PM
SLC Punk's Avatar
Mine does. It maxes out at 6 psi. I also have it T'ed at the FPR
Old May 5, 2004 | 12:50 PM
yoda-g2's Avatar
I'm just wondering that since its at -1 when the engine is off, if that means its reading 1lb less than it should aka 6 = 7. I'm just glad to hear that others are only reading 6lbs.
Old May 5, 2004 | 02:04 PM
SLC Punk's Avatar
Good question. Mine sat at zero when I bought it and it would only go to 6 lbs. So I assume its still accurate..
Old May 5, 2004 | 07:02 PM
Gadget's Avatar
That is odd. I am getting 10+ on mine...
Gadget
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
White Stripe
Oct 6, 2015 10:47 AM
LCE_Performance
Oct 1, 2015 01:03 PM
83
Sep 27, 2015 04:13 PM
