Transmission problem???
Old Oct 21, 2002 | 12:05 PM
swerks's Avatar
Angry Transmission problem???
I own 99 v6 automatic SR5 4x4, While at speed (50-70 mph) if I let off the gas I get kind of a clunk. If I ease off of gas no problem. Any one else experience any thing like this. I have about 48000 mi on the truck and had tranny fluid changed about 2 months ago.
Old Nov 24, 2002 | 06:32 PM
swerks's Avatar
thought I would bump this up to see if I could get a response ????
Old Dec 30, 2002 | 05:27 AM
eagleklaw's Avatar
My 96 4runner does something like that between 60 and 65 it make a clunk or shudder. Like it is having a hard time shifting into or out of overdrive. I can't beleive no one on this board has an answer for this. I did the $160. trans flush and had the timing belt changed.It still does it Help!
Old Dec 30, 2002 | 11:14 AM
eagleklaw's Avatar
I found out today from a friend that there is a product called Dr. Tranny instant shudder fix I bought a tube today I,m a little hesitant but he said if this didn't fix it I would need a new torque converter. I can't try it until my daughter come back from New Orleans fri. I,ll post on how it works. I'll try anything for 12 bucks.
Old Dec 30, 2002 | 01:56 PM
HBoss's Avatar
Most likely because no one else has or has had the problem?
I wish I knew what to tell you...what are the ingredients in that 'tranny instant shudder fix'? I'm kind of curious as to how it knows what the shudder is, and how to fix it.
Is 'instant shudder fix as to tranny', as 'slick 50 is to engine' perhaps?
I hope it fixes your problem..
Al
Old Dec 30, 2002 | 04:21 PM
ravencr's Avatar
Just wanted to let you know you might want to check with Level 10 Performance Transmission Systems at www.levelten.com They have been really helpful to me, but they are not cheap. They will, however, be able to tell what the problem is! From there it's your decision whether to use their services or not. I'm getting a little slipping around 80 mph, when the tranny downshifts from Overdrive. It will downshift fine, but when it goes to shift back into overdrive, it actually revs up about 500 rpm, and then engages finally and drops the RPM's back down. Sam, at Level 10, said that my tranny is definitely slipping. I'm going to take his advice and purchase the PTS kit, and send them my valve body and torque convertor, so I will have a bomb proof tranny able to handle up to 800 hp. I've got the supercharger, but I'm holding off to install until this tranny work is complete. Hope this helps!
Old Jan 8, 2003 | 06:18 AM
eagleklaw's Avatar
Just wanted to let everyone know that the Dr. Tranny shudder fix did work.I put it in and my daughter drove to Auburn which is about 80 miles away.She called and said it never did it during the trip.So I would try this before anyone spends 5or 6 hundred dollars on a torque convertor.Do a search on the internet under the name and you will find out where to buy it.Hope this helps
Old Jan 8, 2003 | 03:28 PM
jx94148's Avatar
Sorry you didn't get replies right away.
I was thinking it may be worn ring and pinion in the rear diff allowing play and a clunk when suddenly going from acceleration to deceleration or vice versa. I'm not familiar with automatics very much. I hope your problem was solved.
Old Jan 15, 2003 | 12:53 PM
ravencr's Avatar
Yeah, I just wanted to let everyone know that Dr. Tranny Instant Shudder Fixx worked for my 1998 4-Runner, which totally amazes me how a small tube of mysterious liquid would make that much of a difference. I'd recommend it to anyone!
Chris
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
