Which Transmission
Old May 16, 2008 | 08:46 AM
TallEddie's Avatar
Which Transmission
Hello,
Hopefully someone can let me know what transmission I have. Specs: 96 Tacoma 4x4, 4cyl, std cab. I have the 3RZ-FE motor. I have not been able to find what transmission was used with this setup. I see lots of write-ups that say the R150F was used behind the V6 in that year, but nothing about which transmission was used with the 4cyl. I am considering turning the truck into my project, since it will no longer be a daily driver next year, and I want to start researching some of my options.
Thanks.
Old May 16, 2008 | 08:49 AM
fillsrunner4's Avatar
http://www.marlincrawler.com/htm/transmission/7a.htm check that site. Its the w-series
Old May 16, 2008 | 11:04 AM
TallEddie's Avatar
Thanks, thats exactly what I needed to know.
Old May 16, 2008 | 11:07 AM
DeathCougar's Avatar
It would be teh W59 transmission. Chaindrive transfer case.
It is posible to put the stronger R-series in with the use of different bellhousings but your w-series should be just fine as its also a very nice transmission
Old May 16, 2008 | 01:01 PM
TallEddie's Avatar
Will the w-series hold up to the torque of a Chevy 350 or 4.3Vortec engine? That is one of my ideas. Never knew that swap was done until I found this site.
Old May 16, 2008 | 01:21 PM
I would upgrade to the R151F the w-series I dont think would like that power. search thoses swaps and you should be able to find all the info on it and what works and doesnt
Old May 16, 2008 | 01:25 PM
1stgen4gunner's Avatar
Old May 16, 2008 | 02:25 PM
JamesD's Avatar
The Tacos have chain for the W series trans? It doesn't follow the older trucks with a gear driven case? Do they even make gear driven cases anymore?
James
Old May 16, 2008 | 02:45 PM
James
Heres the T-case bible
http://www.marlincrawler.com/htm/tra.../tcaseinfo.htm
They only make the chains for the tacos and 4runners. no more gears
Old May 16, 2008 | 03:02 PM
95yoda's Avatar
So gear is better then? or chain?
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
