Traction bars?
Old Jan 7, 2005 | 05:45 PM
Tacoma750's Avatar
Traction bars?
If you used a traction bar in the back, would it take away form your flex in the rear end? How can you use a trcation bar and stilll get MAX flex?
Old Jan 7, 2005 | 05:49 PM
deathrunner's Avatar
If you used Heim joints I think you can achieve this
Old Jan 7, 2005 | 06:47 PM
rockota's Avatar
http://www.budbuilt.com/new/traction_bars.html
That's exactly the type you need - it will prevent all axle wrap and allow full articulation. Mine is homemade, but basically the same. Bud's is great in that it requires no welding.
Old Jan 7, 2005 | 07:45 PM
4Crawler's Avatar
Anti-wrap leaves are another option. They work well and have no impact on flex. Many of the better aftermarket rear springs come w/ a/w leaves already installed, such as the Alcans I used to run:
Basically, it is a halflength leaf on top of the spring pack with a clamp running underneath the pack. It works by pulling up on the clamp in response to the axle trying to twist upward.
They worked so well, I added some to my home-made front springs:
http://www.4crawler.com/4x4/4R_suspe...l#Update-part2
You can see the a/w leaf on the top of the rest of the leaves:
Old Jan 8, 2005 | 08:13 AM
CBIguy's Avatar
here's one I built for an SAS taco with a D60 rear end, the shackle and hiem are the key to flex
Attached Thumbnails Traction bars?-dans-diff-mount.jpg   Traction bars?-dans-shackle.jpg
Old Jan 8, 2005 | 12:42 PM
ZeroYota's Avatar
Do they have fitment for 7.5" rear? The reason I ask is because my 84 2wd pickup has a 7.5" rearend but on Bud's site, they only list 8".
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
