Tow Hooks
Old Apr 19, 2003 | 08:21 AM
CTB's Avatar
CTB
Tow Hooks
Hey guys,
Well since we had a big discussion about tow straps and all that earlier, I figured I would ask a question about tow hooks. I looked on the front of my rig, and this "eye tie-down" is actually bolted down. So, I was thinking about removing the "eye tie-down" and replacing it with an actual tow hook...should that be alright? Second question, are all tow hooks created equal, or is there something specific to look for? I don't know a whole lot about recovery, so I'm hoping you guys will be able to give me some info. Thanks for all of the help-
CTB
Old Apr 19, 2003 | 08:26 AM
Yoda's Avatar
I don't know if there is a quality difference between hooks. I do know it is best to get those hooks that have that safety latch so the strap/cable/whatever doesn't fall off if there is any slack in the line.
Old Apr 19, 2003 | 08:40 AM
Corey's Avatar
Co-Founder/Administrator
Cody, here is a vendor that I have a link to in the Vendor Links section.
http://www.recoverygear.com/DEFAULT1.HTM
By looking in their recovery hardware section, I see these.
http://www.recoverygear.com/hardware.html
Perhaps something like that can be made to bolt on where you want it to?
Then use a shackle with it that is further down on that page.
I now know why my Masterpull synthetic line was so much money, the dang yellow hook and coupling are close to
$100 alone.
Old Apr 19, 2003 | 01:32 PM
CTB's Avatar
CTB
Thanks for the replies guys. I'm thinking about picking this one from Warn (it's about halfway down the page).
Anyone else have any comments/ideas/suggestions?
I really appreciate the input.
Old Apr 19, 2003 | 02:07 PM
OicnaiC's Avatar
Don't you already have a tow hook on the other side? Whats wrong with it? Whats the advantage of 2? I've never had a probelm with only 1 tow hook.
Old Apr 19, 2003 | 03:35 PM
Hawaiian4R's Avatar
Yeah, don't you have one on the other side?
Old Apr 20, 2003 | 07:18 AM
CTB's Avatar
CTB
Ya I do, but I was going to add one just in case...the tow rope may not quite be long enough, it may be easier to get one side of my car into a tight spot to make a pull than another, etc. It's pretty much for a "just in case" situation.
Does anyone else have any more comments? Thanks guys-
Old Apr 20, 2003 | 02:09 PM
RTdawgs's Avatar
keep the tie down. if your strap isnt long enough for the factory hook, move the vehicle that isnt stuck.
Old May 1, 2008 | 01:59 PM
wolf's Avatar
I wanted another one also and having a hard time finding them. Any help would be appreciated. Thanks
Old May 1, 2008 | 02:27 PM
bigt's Avatar
go to a junk yard an d take the one from the other side!! and then put it on the other side... i have found just a d rong in that tie down is better than a the tow hook i use it more!! ymmv
Old May 1, 2008 | 02:28 PM
norcalsvx's Avatar
see if sdori will make a set for you
Old May 1, 2008 | 02:29 PM
Tacoclimber's Avatar
An eleven post thread revived after 5 years??? This has to be a record!
Steven.m.paulk
Jun 7, 2020 10:45 AM
smilen724
13
Nov 8, 2015 04:11 PM
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
