Tire/wheel size
Old Oct 8, 2003 | 08:37 PM
MellamoPOUND's Avatar
Tire/wheel size
hey, I am buying a 2000 4runner pretty soon, and i am going to put 2.5" suspension lift on it. I am pretty sure that that will allow for 285/75/16 tires, which are what 33's? Now, if i were to put lets say 2 more inches in body lift, what size tires could i fit? Also, I dont understand things like offset and backspacing. Could someone please explain? Thanks
Old Oct 9, 2003 | 09:43 AM
Old Oct 9, 2003 | 10:02 AM
ty_yoda's Avatar
welcome.. im fairly new too
everyone here is going to tell you to use the search function and look for tire size....
its all over the forum and these old guys hate repeating themselfs
good luck
Old Oct 9, 2003 | 10:21 AM
Sac State's Avatar
LOL, its the same question by a new person everyday.
Old Oct 9, 2003 | 07:01 PM
Good Times's Avatar
MellamoPOUND:
With a 2.5" suspension lift you can add some 285's(33's) with minor rubbing at full lock and full compression. Pounding and trimming will get rid of this problem.
I think with the 2" body lift you can go up to 35's but I can't personally guarantee that as there are only a select few members here that have 35's (2 I think). I don't remember exactly what their setup was but I'm certain the with atlesat 5-6" lift (total, body and suspension), you should be able to get 35's in there.
As for offset and backspacing, well depending on the tire size makes the diff I think. I know people use different backspacing/offset for the 33's and 35's so I would suggest doing some homework
https://www.yotatech.com/forums/show...4&highlight=35
sample link should give you some info to get ya started. The search feature works well as long as you go through each one in detail. It takes time but I know this topic has been discussed awhile ago so start diggin
Old Oct 10, 2003 | 01:53 PM
thanks!
Old Oct 10, 2003 | 03:38 PM
RTdawgs's Avatar
2.5" susp + 2" body will clear 33x1250s on an 8" wheel for sure. my buddy has this set up.
35x1250s will be a stretch, not to mention stressful on your driveline.
Old Oct 11, 2003 | 04:07 PM
Cebby's Avatar
...its all over the forum and these old guys hate repeating themselfs
HEY! How did you know I was old?
smilen724
13
Nov 8, 2015 04:11 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
oldblue
Sep 28, 2015 04:07 PM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
