Timing belt kit question
Old Feb 27, 2013 | 05:45 PM
crazypaint's Avatar
Ok I'm picking up a used motor has 78k on it. What all should I do for the timing belt stuff. I know timing belt and water pump what else should be done thanks also oem or name a good aftermarket brand. Wanna be good for the next 100 k
Old Feb 27, 2013 | 06:03 PM
rworegon's Avatar
https://www.yotatech.com/forums/f2/g...lt-kit-265796/
A 3.4l engine? If so, the kit in post 1 or 6 above (or AirCabinMans less expensive kit) will do the job. Also, pick-up a crank bolt from the local dealer as it's listed as a non-reusable part.
Post 1 here for a very good tutorial.
Old Feb 27, 2013 | 06:10 PM
crazypaint's Avatar
Ya my bad 3.4 thanks
Old Feb 27, 2013 | 06:12 PM
rworegon's Avatar
Welcome!
Old Feb 27, 2013 | 07:42 PM
98SR54RUNNER's Avatar
How much is a motor with that low mileage costing you, if you don't mind me asking?
Also, here's FSM timing belt docs:
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 28, 2013 | 01:34 PM
crazypaint's Avatar
I got lucky and found one on Craigslist for 550 I pick it up. O by the way I did use the search just so everyone knows. The motor was a steal
Old Mar 2, 2013 | 12:44 PM
crazypaint's Avatar
Got the motor will post pics tonight
Old Mar 6, 2013 | 09:16 AM
Renaud33's Avatar
Where are the pics??
Old Mar 6, 2013 | 08:12 PM
crazypaint's Avatar
Lol damn motor swap started early I will try to post them soon I get ou of work then go work on it till midnightish I hope it's worth the motor change heap cause its a pia
Old Mar 7, 2013 | 07:30 PM
crazypaint's Avatar
New motor
Old motor
Hole in old motor lol
Blew the oil filter and threaded nipple right off he'll of a mess getting the old motor out. I got the valve covers and intake cleaned up tonight and found some spray bomb silver looks better than they were. Had to switch out the exhaust manifolds and crosse over pipe. Apparently 99 and 02 are different. Will post more pics tomorrow
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Mar 7, 2013 | 07:31 PM
crazypaint's Avatar
New motor
Old Mar 7, 2013 | 07:32 PM
crazypaint's Avatar
Old motor
Hole in old motor
File Type: jpg
Old Mar 7, 2013 | 07:33 PM
crazypaint's Avatar
Sorry iPad is going crazy
Old Mar 7, 2013 | 07:34 PM
crazypaint's Avatar
For some reason my pics were messed up but ya get the idea ill try to straighten it out later
voiddweller
19
May 2, 2016 09:10 PM
stagger_lee
Mar 29, 2016 06:27 PM
layifioren
10
Jul 6, 2015 02:26 PM
marcusSRG
Jun 27, 2015 07:13 AM
infinityisfive
Jun 16, 2015 06:51 PM
