Ticking sound.
Old Aug 24, 2004 | 08:15 AM
PC97M3's Avatar
Ticking sound.
There is a slight ticking sound coming from my engine bay. It seems to come from the driver side of the motor. I had it checked out at the dealership and they said it is normal. Does this seem normal? BTW. It is a 2001 4runner limited with 56k miles. I also have a 1997 limited (with 158k miles) and it does not make the ticking noise. Any input would be appreciated.
Thanks
Paul
Old Aug 24, 2004 | 08:21 AM
BC-4Runner's Avatar
I am not sure if it is the same thing, but I have a ticking sound that comes from a module/sensor on top of the Charcoal Canister on the driver’s side of the engine bay.
Not sure if this is normal or not....
Old Aug 24, 2004 | 09:32 AM
MTL_4runner's Avatar
Ticking could be a small exhaust leak close to the head but it is tough to say without hearing it.
Old Aug 24, 2004 | 09:38 AM
PoBoy's Avatar
Do you hear it from the inside of the truck? Does it go away when you press on the gas?
Old Aug 24, 2004 | 10:52 AM
PC97M3's Avatar
I do not hear it from inside the truck. It does not go away when I press the gas. But, when I first startup in the mornings, I do not hear the ticking.
Old Aug 24, 2004 | 11:09 AM
DrummerDaveB's Avatar
I believe you're just hearing the infamous "ticking device".
My 98 has one too.
Old Aug 24, 2004 | 11:50 AM
roger's Avatar
my '98 makes a similar noise. so it is normal?
Old Aug 24, 2004 | 12:53 PM
havic's Avatar
My 98 occasional makes that noise too.
Old Aug 24, 2004 | 03:26 PM
midiwall's Avatar
Does it also happen with the engine off? If so, then you're hearing the EVAP canister purging. It's part of the emissions control. You'll find that it'll stop if you loosen the gas cap.
Old Aug 24, 2004 | 07:21 PM
PC97M3's Avatar
Ticking only happens when engine is running.
Thanks for the replys.
Paul
Old Oct 23, 2004 | 07:35 PM
Henryv's Avatar
Mine is makeing the same noises too. Dont know if it did it before but it does now. Anyone find out what it was and if its normal?
Old Oct 24, 2004 | 02:45 AM
stockerjo's Avatar
Thanks
Paul
I have a 2004 Limited V8 (850 miles) with a similar noise. Right after start up, no tick. After it runs for awhile, I can hear the faint tick, but only from the outside with the hood raised. Holding a listening tube to my ear, it seems to be coming from the top area of the cam chain cover. Under warranty for seven years. Not going to worry about it. Worse things can happen. My Yamaha V Star 650 motorcycle engine ticks and whines. My Suzuki Hayabusa engine rumbles and whines. Must be a Japanese thing.
I'm new to Toyota, but didn't they switch from timing belts to timing chains somewhere along the line? Anyway, whatever the sound is, if your Toyota dealership says it's normal, relax and forget about it. They are doing you a favor.
Stockerjo
Old Oct 24, 2004 | 10:12 AM
VolcomTacoma's Avatar
I have the same ticking on the passenger side of my 98 3.4. I can hear is slightly at freeway speeds too. It is the EVAP valve by the charcoal canister and heard this was normal. I know there was a fix for some late models. You can distincly hear the noise coming from there if you lift the hood and listen closely to it.
Old Oct 24, 2004 | 11:06 AM
InFlames's Avatar
look for missing bolts or nuts on the exhaust headers flanges they fall out sometimes and cause a small crack that lets exhaust escape and make a ticking noise when you applythe gas..
Old Oct 24, 2004 | 11:16 AM
I already know its the valve by the charcoal canister making the ticking.
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
Tacoma1313
Sep 15, 2015 07:51 AM
ErikZ1220
Sep 10, 2015 04:53 AM
larrys93pickup
Sep 6, 2015 06:37 AM
