Swaybar Discos: Which would you reccommend?
Looking into getting a set of swaybar disco's, which would you guys reccommend? And for a good price too.
Also are they all pretty easy to install?
Rob,
yeah I had to use a drill. No big deal. I have a 18v Dewalt. The install was only complicated by me not installing the bolts so that the cotter-pins tilted slightly. when I fixed that it was a breeze.
Check out my pics:
http://www.net-impress.com/4runner/disco/
Dan
Check out my pics:
Dan
I think Rockstomper stopped making them, and from what I hear they sucked
I will probably have to ditch them once I get my lift on though.
Re: Swaybar Discos: Which would you reccommend?
I have the Rockstomper's still in the box. I no longer plan to install them. Let's make a deal.
Mike
Mike
Hey Rob-
If you are on a budget, and have access to a welder or know someone who does, you can make a set of Lars' discos for about half of what he charges. Its pretty easy if you have a decent hardware store near by. When I made my set, I had to order the rod ends from Summit Racing...
Remember that the disco's are only a convience. You can take off the stock disco's and put them back on in about 15 min or so.
If you don't wheel often, (like me.. haha) I would suggest trying this route and see if you hate it so much you are willing to spend $80 to fix it.
Dan
Dan
Dan
Dan
Your rig has disco's already. They are just not "quick" disconnects. There are two nuts that have to be removed on each side. You can just disconnect those instead of buying "quick" disco's.
What I am saying is that $80 saves you 10 min every time you go wheeling.
Dan
Dan
justdifferentials
Sep 5, 2015 06:52 PM
