swap auto with manual
Old Mar 22, 2004 | 03:00 PM
TheTank's Avatar
I was just wondering if it was possible to swap an automatic transmission with a manual transmission. In a few years I'm planning on putting in a 3.4L and new transmission in my '91 4Runner when i do my SAS and turn it into a rock crawler. I know there will be alot of cutting and stuff around the floor and that kind of stuff, but if I found a computer from a 3.4L that had a manual transmission, plug that into a 3.4L engine, add a manual transmission along with a Marlin crawler.....would this work out alright? I like the idea of a manual rather than the weaker automatic with big tires and everything. Just an idea.
Old Mar 22, 2004 | 05:07 PM
toy283's Avatar
Sure. Just raid the boneyards for the manual tranny parts. You'll need the brake/clutch pedal assembly, mastercylinder, stainless steel line, clips, brackets, etc. in addition to the obvious stuff. It's not like '91's were never available with a manual so the converssion itself shouldn't be too hard.
Old Mar 22, 2004 | 06:20 PM
blackrunner91's Avatar
cool, i'm collecting parts right now to do the same thing. The only things I still need are the custom harness(I already have the stock 3.4 harness), a good 5-speed(the one I'm getting with the engine needs 2nd and 3rd gear), and a clutch. Other than that, it'll just be small things here and there. Oh yeah, and an exhaust. I do have a question though, can the stock auto crossmember be used with the manual trans.???
Old Mar 23, 2004 | 02:23 AM
toy283's Avatar
Originally Posted by blackrunner91
...I do have a question though, can the stock auto crossmember be used with the manual trans.???
Dunno. I think I've heard that you can maybe with a little relocation. I'm sure a simple adapter plate can be fabbed up to go between the crossmember and tranny anyway.
Old Mar 23, 2004 | 04:10 AM
woodworth's Avatar
Hey Tank:
off topic but i posted this in another thread and haven't recieved any reply's
for over a week so here goes. I have the same runner as you except a 94,
it has a 3.0, auto and 31" tires. Door jam sticker says it came w/ 225/75/15's stock, what gears are in my runner. I've owned it for a year and
can't figure out the gears tryed offroad.com , dealer code says G144
Woody
Old Mar 23, 2004 | 09:00 AM
Highland Runner's Avatar
A guy on OffRoad.com did this swap recently. I can't seem to find it now, but it was less than a month ago when I read it. He documented the whole process. The crossmember should be the same for the manual and auto. You may need to get the 3.0 ECU for the manual trans untill you do the 3.4 swap.
Edit: I found the link
http://bbs.off-road.com/ubbthreads/s...ue#Post1262965
I think he bought stuff that wasn't needed, or new, so it could be done for cheaper.
Now my question is can this be done to a double cab Tacoma since they are ALL auto's. I wonder if there are punch outs or spots to put pedals, slave cylinder, etc.
Old Mar 23, 2004 | 11:57 AM
TheTank's Avatar
Originally Posted by woodworth
Hey Tank:
Woody
I had my gears changed about 4 months ago and I found out that the stock gears were 4.56 and I upgraded to 4.88's with the 33" MT/R's, but now I wish I had just gone with the 5.29's so I will be all set up for the 37" MT/R's I'm going to get after I do the lift and swap and everything. But anyways, yeah they should be 4.56 I'm pretty sure.
Old Mar 23, 2004 | 12:35 PM
man that thread about the swap was awesome. It will make our swaps a LOT easier.
Old Mar 23, 2004 | 02:51 PM
woodworth's Avatar
thanks tank
sorry to take you off your question. i found another thread that told you
how to figure it out by lifting the rear wheel and watch how many times the
drive shaft spins. about 4 1/2 times
good luck w/ the swap
Woody
88sasturbotoy
Jan 30, 2026 01:57 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
deepmarsh
Aug 6, 2015 03:44 AM
KBar
Jul 13, 2015 06:01 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
