Steering Stabilizer removal help
On my 1st gen I am replacing the steering stabilizer and can't get one bolt out. The end of the shock which mounts to the frame utilizes a bolt which is runs through the rubber bushing on the shock. I have the nut off and the bolt will turn freely, bu the problem is the rubber bushing is stuck to the bolt and it will not let me push it through no matter what. Any suggestions on freeing this up? Any type of rubber eating compound on the market?
Thanks,
Martin
Thanks,
Martin
If I am thinking of what your talking about could you cut a line in the rubber with like a hacksaw or a pneumatic grinder and then use a screwdriver or something to peel the rubber off the bolt.. just and idea
I have tried to remove as much of the rubber as I can reach. The problem it's seems to be stuck and no matter what I put at it doesn't budge. I think I might try some small c-clamps to help force it out. A hammer is getting no were.
Martin
Martin
here's an idea-try a small torch, soldering torch or a pencil torch that is butane powered, just enough to heat the bolt without melting the rubber completely..... get it nice and warm, and wack it with a big fine hammer.... 4lb mini sledge, and if you cant get a good swing in at the bolt, use a long extension as a punch :X
hope it helps
hope it helps
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 5, 2015 06:20 AM
probably some of your frame too though.
