Steering Stabilizer removal help
Old Feb 2, 2003 | 11:06 AM
martin's Avatar
On my 1st gen I am replacing the steering stabilizer and can't get one bolt out. The end of the shock which mounts to the frame utilizes a bolt which is runs through the rubber bushing on the shock. I have the nut off and the bolt will turn freely, bu the problem is the rubber bushing is stuck to the bolt and it will not let me push it through no matter what. Any suggestions on freeing this up? Any type of rubber eating compound on the market?
Thanks,
Martin
Old Feb 2, 2003 | 11:18 AM
UKMyers's Avatar
If I am thinking of what your talking about could you cut a line in the rubber with like a hacksaw or a pneumatic grinder and then use a screwdriver or something to peel the rubber off the bolt.. just and idea
Old Feb 2, 2003 | 11:23 AM
martin's Avatar
I have tried to remove as much of the rubber as I can reach. The problem it's seems to be stuck and no matter what I put at it doesn't budge. I think I might try some small c-clamps to help force it out. A hammer is getting no were.
Martin
Old Feb 2, 2003 | 12:57 PM
rowan's Avatar
go to VIP and get some battery recharger. its hydrochloric acid, 12 molar i think. strong stuff.. should eat away your rubber probably some of your frame too though.
Old Feb 2, 2003 | 01:05 PM
Eighty7ToyTruck's Avatar
here's an idea-try a small torch, soldering torch or a pencil torch that is butane powered, just enough to heat the bolt without melting the rubber completely..... get it nice and warm, and wack it with a big fine hammer.... 4lb mini sledge, and if you cant get a good swing in at the bolt, use a long extension as a punch :X
hope it helps
Old Feb 2, 2003 | 04:13 PM
martin's Avatar
Tried the torch and the no movement. I have given up for today and may have to farm out.
Martin
Old Feb 2, 2003 | 04:14 PM
Cebby's Avatar
Torch it
The torch is a great idea. I was going to have my friendly local 4x4 shop do my bushings (switch to urethane) and they said they'd have to BURN the bushings out. It must work...
Old Feb 2, 2003 | 05:28 PM
Well, bring it to fort myers, florida and to the galloway ford service, ill fix it... heh
Old Feb 3, 2003 | 04:38 PM
martin's Avatar
Well the Dewalt took care of it today. Well it is time to install the new OME damper. Since I trashed the bolt I will be getting a grade 8 tommorow. Damn bolt!!
4x4-runner
Apr 18, 2017 09:08 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 5, 2015 06:20 AM
gillesdetrail
Aug 3, 2015 04:43 PM
bobpat
Aug 1, 2015 09:25 PM
