sputtering 22RE??
sputtering 22RE??
ok,my runner has been sputtering and missing for a while now. so i replaced the fuel filter, plugs, wires,cap and rotor, fuel pressure regulator and put new OEM fuel enjectors in it...and it still sputters :pat: what else could it be?
Read this thread: https://www.yotatech.com/forums/f116/22re-crank-case-pressure-blowing-dipstick-out-40614/
Maybe something like a burned valve?
Have you checked the cap and rotor? I know every now and then that my cap button get destroyed for some reason. also check the wires for resistance. The Haynes manual should tell yopu how to do it. (although I have checked mine and they are out of range but still work fine)
Originally Posted by SoCal4Running
Check to make sure all your fuel injector electrical plugs are tight on the injectors, we have one with a broken clip retainer and sometimes it falls off.
well,i found the complete fuel pump with 50K on it for $21 on ebay so i got it..
Originally Posted by seaflea
If you talk with Mike , he has a fuel pressure regulator tester and some other nice gadgets to help diagnose youre problems. Last I talked with him, he had his garage just about in order to start working on some stuff.
maybe i can get up there one day this weekend..
im going to try the fuel pump next
