!!Speedy's Supercharger Thread!!
Old Feb 4, 2010 | 01:08 PM
  #861
Speedy's Avatar
I'm not sure how a 7th injector will help hross14? The injector is installed into the port on the supercharger. Since you don't have a supercharger I don't know where you'll put that injector.
Old Feb 4, 2010 | 01:10 PM
  #862
mastacox's Avatar
Originally Posted by hross14
4Runner is a 1999 AFR equiped
I AM LISTENING GUYS--Dont get fustrated--i am also a motor guy t0-before all this--it was easy to dial in fuel and initial timing--We have more compression in the engine than stock and 2% leak down--the motor was built exceptionally well--Not much more compression but I would like to take advantage of that and optimize. IF it does run FAT in open loop--I want to dial in more timing thier also--
You can tune it and see what happens, don't expect monster increases though.
Also, IIRC, closed loop operation is only "on" till the motor warms up right? after that it is in "OPEN" loop? Are we on the same page?
No, the motor operates in closed loop all the time unless you're at full throttle. Any fuel changes you try to make will be countered by the control system unless you use a URD AFR Sensor Calibrator.
So here is what I am thinking
MAP-ECU2 for timing, speedo adjust, and CEL cancelation (add the AFR Module just in case)
DO you have the CEL because you removed the rear O2 sensor, or because you cat is bad?
Nobody has answered this yet--but what AFR gauge do yall like best? Looks like LC-1 is popular--what do you think about the multi gauges like the PLXs' with integrated OBD capabilities?
For plain wideband, I think the Innovate Motorsports ones are the best. But if the PLX gauge can do wideband and OBD-II together, I would seriously consider that one (although it will be significantly more expensive).
Here is the Innovate combo I have: Standalone Gauge Kit, LC-1 and XD-16- $329
Here is an option if you don't want the expensive XD-16 gauge: DB-Blue Gauge / LC-1 Kit- $229
Old Feb 4, 2010 | 01:33 PM
  #863
hross14's Avatar
DO you have the CEL because you removed the rear O2 sensor, or because you cat is bad?--Aftermarket CATS[/URL]
i wouldnt add the 7th injector Speedy until i went SC.
Mastcox--I do plan on tuning it and see what happens--i dont think much will--maybe another 15-20 if i am lucky--and i would live with that. If I could
However, when I do floor it--you can feel the slight bump in power....
Old Feb 4, 2010 | 02:13 PM
  #864
mt_goat's Avatar
So you're wanting to advance the timing aren't you? Most of us, maybe all of us with a blower, are taking timing out, retarding to take out ping. Mostly in the low rpm w/boost range. The ECU does a nice job of advancing the timing. Using the knock sensors (above 3000 rpms) it advances the timing until it detects knock and then backs off slightly. I doubt you'd be able to improve on that variable tuning of the timing. Having high compression will make knocking worse too.
Old Feb 4, 2010 | 04:05 PM
  #865
Texas_Ace's Avatar
I agree, the stock system will advance timing till it senses knock and then back it off. So you can't advance it any further anyways.
Old Feb 5, 2010 | 05:43 AM
  #866
hross14's Avatar
Guys, if the Knock sensors dont come on till 3000 rpms then that doesnt work for me. Most of my driving is done in the 3000 and below range.
Its also important to remember that as you increase duration, lift, and compression--you need more timing to make pressure in the cylinder. Thats why modified motor dial in more initial timing. I will run it on a chassis dyno and dial it in. Maybe we might all be surprised?
AND a FUN FACT--We could not degree my cams when we were building the engine.......but some older engines can be off as much as 8 degrees (Cam to Crank Relation) from the factory!!!!! It makes a world of difference. It would of been nice to dial in my cams but it was just to complicated.
I read somewhere that each cam scissor tooth is worth 3 degrees--so you would make adjustable timing belt gears--advance the intake ~1.5 degrees and then you would have 1.5 degrees advance on the exhaust---you get the picture.......
So let see what happens--thanks for the help guys--it was the computer theory i was most worried about--engines are easy HHaaaa
Old Feb 5, 2010 | 05:57 AM
  #867
mt_goat's Avatar
Sounds something like my BMW VANOS engine (timing chains though, not belts): http://www.usautoparts.net/bmw/technology/vanos.htm
Old Feb 5, 2010 | 09:39 AM
  #868
hross14's Avatar
I am talking about the fixed scissor gears for our cams. If you advance/retard the intake cam via the timing belt gear XX degrees then retard/advance the exhaust camshaft you come up with a net valve for the exhaust cam. For example:
1. Advance intake cam via timing belt gear 1 degree
2. Then advance/retard the exhaust cam via the scissor gear (=3 degrees)
3. Your net exhaust cam advance would be 4 degrees and retarded 2 degrees.
See what i am getting at here--we could theoretically play with cam timing in relation to the crank.
Think about this--A Jag AJ16 (4 liter) engine uses the same cam profile for this motor whether it is Supercharged or NA. The only difference is the cams are timed differently.
Old Feb 5, 2010 | 10:36 AM
  #869
hross14's Avatar
This kind of 3.4 motor stuff would be great to condense into a wiki or something like that--
This motor stuff i know through messing with motors prior to computers and such...
The basic premise is the same for all motors--How much can you make it SUCK. More it sucks--the more power you get
Old Feb 5, 2010 | 10:45 AM
  #870
mt_goat's Avatar
That's a good way of looking at it. Makes you wonder about all the air filter and intake hype to allow it to breath better. The engine is a powerful positive displacement vacuum pump, it will suck in the air though the stock air filter just fine.
Old Feb 5, 2010 | 10:56 AM
  #871
hross14's Avatar
Yeah, i would say so--I run stock--i do have the deck plate mod ....but hey--the air box was out when i did the motor so.....
Old Feb 5, 2010 | 11:00 AM
  #872
Speedy's Avatar
On the air thing...
I dyno tested several a few years ago along with the deck plate mod. The figures are on my site somewhere, but getting a good air filter and the deck plate mod was good for about 10HP in back to back runs if memory serves.
I also gained about 5HP on my Challenger doing a cold air intake on that vehicle in back to back dyno runs over stock. I think picked up a few more ponies doing a cat back exhaust.
The more air you can get in and out of a motor the better it'll run.
Old Feb 5, 2010 | 11:07 AM
  #873
mt_goat's Avatar
Originally Posted by Speedy
On the air thing...
Yeah I guess, probably more important at dyno-type rpms though.
I still get over 10 psi boost with the stock filter and no deck plate mod.
Old Feb 5, 2010 | 12:43 PM
  #874
Speedy's Avatar
I have the stock air filter in mine too, although I do have the deck plate and ISR mods. I usually see the same...10.5psi although in the cold air I've seen 11psi.
Old Feb 5, 2010 | 06:50 PM
  #875
Texas_Ace's Avatar
Also note that you have a 2.2 pulley and he has a 2.1. I wounder why you get differnt boost levels?
Old Feb 5, 2010 | 06:54 PM
  #876
mastacox's Avatar
I get about 7 psi max here with a 2.2" pulley, deckplate, and Amsoil TS foam filter; but I live at 7000ft asl. IIRC in Tucson I could get about 9psi (2400ft asl).
I would call the 2.2" pulley a 9psi pulley, and the 2.1" pulley 12psi. Not sure what accounts for Dale's discrepancy though...
Old Feb 5, 2010 | 07:37 PM
  #877
Speedy's Avatar
I dunno. Maybe I got a "defective" 2.2" pulley or maybe my blower is just more efficient?
Old Feb 6, 2010 | 05:02 AM
  #878
mt_goat's Avatar
My engine sucks harder, the SCer can't keep up.
Old Feb 8, 2010 | 07:00 AM
  #879
hross14's Avatar
Guys--Speedy--Et al......i think we should really look into playing with the cam teeth. Talked to the Motor Gurus Friday and though Asian motors usually have Decent cam specs--there is a difference between SC cams and N/A cams. The lobe separation is different....and other such things.\
SO--is there anyway we can find out the actual cam specs. Then i will talk to the guys and see what they think.
We would need basically everything about them. We may be horsepower penalizing ourselves. From what i was told--it looks SC'er would be need about ~6-8 degrees more lobe separation and NA'ers about ~4.
Maybe we could pitch in and find a crashed motor to play with........
Old Feb 8, 2010 | 07:15 AM
  #880
Speedy's Avatar
I'm not sure it'd be worth it on this motor. Yes, a specialized supercharger cam will give you more power. It basically holds the intake valve open a bit longer to allow the blower to push more air into the cylinder.
However, I'm already at about 300HP on this engine. I'm not sure more is really prudent here. The supercharger cam may add another 25HP or so. It would be interesting to see. However, the cam would have to be designed/tested/ground/etc. Could get quite pricey for an out of production motor.
I thought there was a guy on this site that offered cams for the 3.4L?
