So I wanna lift my 98 2wd...suggestions?
Old Jul 27, 2003 | 07:59 AM
iLikeBeer's Avatar
I have a 98 2wd and have been looking at lifts for a while but haven't really been able to find anything besides spacers and shocks.
My ultimate goal is to get to 35's, but seeing as how this is my daily driver that may not be able to happen (I need to keep the fuel economy going for me). Anyone have any suggestions?
Here's a pic of my old 01 Z71 with a 6" Rancho kit not doing its job:
[img][/img]
Old Jul 27, 2003 | 08:06 AM
TDiddy's Avatar
Pic no worky!
Old Jul 27, 2003 | 08:24 AM
iLikeBeer's Avatar
Sorry, my dialup is all sorts of messed up. The pic is too big to attach, but for some reason it still posted this thread anyway.
I made another thread, somebody please lock this for me!!
https://www.yotatech.com/forums/show...threadid=14726
Old Jul 27, 2003 | 11:26 AM
turboale's Avatar
Well,
I would go with some downey adjustables in the front (0-4" of lift) since you d'nt have any CVs to screw up, you can crank them up to your hearts content. Then get some 3" lift springs and a spacer to bring the azz up (don't forget to extend your brake lines!). Then if your still not satisfied, go with a 2" body lift. I think thats the most body lift thats recomended, but someone correct me if i'm wrong. Good luck!
Old Jul 27, 2003 | 11:44 AM
pfdaxe's Avatar
35s AND fuel economy? Hmmmmmmmmmm
35s will probably rub on turns and you would have to re-gear.
Old Jul 27, 2003 | 07:10 PM
doink's Avatar
yes, 35s and fuel economy sounds like a cop and a full box of doughnuts:pig:
Old Jul 28, 2003 | 08:46 AM
iLikeBeer's Avatar
Well with 4" of lift I should be able to easily run 33's and still have decent highway mileage...right?
Old Jul 28, 2003 | 08:55 AM
pfdaxe's Avatar
I'm running 2.5" lift with 285/75 (equal to 33s) with 16x8 rims and I had to trim the inside of my front flare because of rubbing on turns. Didn't see much differance in milage.
Old Jul 28, 2003 | 11:43 AM
PoBoy's Avatar
Is this for looks mainly?
Id go with Turbodale if you are going to take it offroad, but if its just for looks...
Cheap way: stock 4x4 4Runner springs for 2inches of lift and a 2inch BL = around $150 total. Those springs should be damn easy to find around here. But I dont think 4 inches will get you 35's w/o rub. 33's will be plenty though.
Old Jul 28, 2003 | 11:46 AM
bamachem's Avatar
Stock 4WD 4runner springs will only give you 1" of lift at most on a 2WD... Trust me, I know.
Old Jul 28, 2003 | 11:58 AM
PoBoy's Avatar
Only 1 inch?? Hrmm, everyone go fix your forsale threads
Throw a spacer on then...
Old Jul 28, 2003 | 12:36 PM
turboale's Avatar
I'll sell you mine for $20 plus shipping
Old Jul 28, 2003 | 02:00 PM
fooddude's Avatar
fabtech suspension lifts are the only 2wd lifts i know of
Old Jul 28, 2003 | 02:29 PM
iLikeBeer's Avatar
This will be almost totally for looks, I don't plan to do more than hop a couple curbs or drive across a field with my truck.
If I could get 33's on it I would be happy, I just want to be able to get the best ride as possible and be able to run 33's or bigger.
Old Jul 29, 2003 | 12:51 AM
turboale's Avatar
Then just get some OME coils from mike at xtremeoff-road.com/ (I believe mine came to $280). Or if you want to go really cheap, get a spacer lift kit. Thats all you need, check ebay for the spacers. Considering you can run 31s stock, that should be all he needs right?
Old Jul 29, 2003 | 05:01 AM
RTdawgs's Avatar
any 96-02 "lift kit" will work with 2WD or 4WD. you will get more lift on the 2WD, but the parts are interchangable.
Old Jul 29, 2003 | 09:23 AM
Phisherman's Avatar
I have an OME 880/891 setup with 33x12.5 Duelers and still get ~20 on the highway. Either regear or calculate ~15% when figuring mileage.
punks_is_4x4
May 31, 2016 06:03 AM
4.34runner88
Jan 12, 2016 01:10 AM
Scatterbrain
Sep 3, 2015 06:46 PM
Ryall
Sep 2, 2015 06:48 AM
coffey50
Jul 28, 2015 10:55 AM
