so i go to install my cam today....
Old Mar 25, 2003 | 03:30 PM
decepticon's Avatar
actually it was fri and just got the truck back today. I went to a local toyota to install an crane cam, low torque. it turned out to be a 13 hour night mare.... ok heres a list of things that was found when they were doing the cam. streched head bolt, blown vale gasket, head gasket came unaligned, it was on it way out anyways, timing chain assembly, laking oil from the crank pulley, thermostat. TOTAL=1500 - toyota Emp discount = 847.97 Which is good in a way. Everything else was in good condition, rocker arm assembly, valves, (slight tick) but what you want at a 150k motor? Motor was decarbonized, valves adjusted. The cam is a great product. Its something really you can feel can my 22re feel more responsive. I can feel it in the 2800to 3200 range. Its like a sudden kick. Im still running 4.10 and i am very happy with it. but if it was just a cam install, it would be 180. Up next are my ecu upgrade and 5.29 gears with a lockrite diff, ecu ill do and ill get the gears installed for 480 front and rear. Working at toyota really has its benefits
Old Mar 25, 2003 | 04:25 PM
Skydigger's Avatar
Cool. What was the model # on the cam you bought from Crane? I'm looking at doing the same thing to mine.
Thanks,
Warren
Old Mar 25, 2003 | 05:43 PM
914runner's Avatar
decepticon- In your signature you have a pic of your truck and in the background I see that theres a VW Corrado, is that yours? Thats one of the few VW's I like. If it is yours could I see a few more pics of it?
Thanks
Old Mar 25, 2003 | 06:06 PM
decepticon's Avatar
actually i got it off ebay, you can get em here cams Not bad for 50 bucks and 91.. that coraddo is my cousins, ill see if i can find more pics of it
Old Mar 25, 2003 | 08:00 PM
Skydigger's Avatar
I'm just wondering what model Crane cam you bought because it's a common conception that TRD cams are made by Crane.
As you can see in the link the specs are the same. Is yours the mild one or the more aggressive grind?
Thanks,
Warren
Old Mar 25, 2003 | 08:51 PM
decepticon's Avatar
agressive grind
Old Mar 26, 2003 | 05:30 AM
Victor's Avatar
I wasn't aware that Crane made a cam for the 3.0
Would be nice though.
Old Mar 26, 2003 | 12:31 PM
Skydigger's Avatar
They may not. My signature still describes my 1990 but I also have an '86 with the 22RE I'm working on.
Regards,
Warren
bigjstang
Jun 2, 2025 03:56 PM
RatOmeter
Oct 22, 2015 03:17 PM
nonstop
7
Aug 11, 2015 09:26 AM
daddio
Aug 9, 2015 07:17 PM
Fakayayou
Aug 9, 2015 12:47 AM
