Shaky steering wheel
Old Apr 21, 2008 | 08:03 PM
twitchee2's Avatar
This is very weird, when im driving on the free way, i get a steer wheel shake in a certain speed range of about 62-72mph. Its just fine at all other ranges. I would think if the tires are out of balance it would shake all the time and not at a certain point. I dont think this has anything to do with it but i do have warped rotor not badly but enough to feel the brake pulsing rather then smooth. Anyone got any ideas on the shaky steering wheel?
Old Apr 21, 2008 | 08:29 PM
TOYOTA 1's Avatar
id say its your tires.
Old Apr 22, 2008 | 04:40 AM
gpcollen1's Avatar
Balance issues usually show up in a speed range - that looks somewhat like your issue.
Old Apr 22, 2008 | 05:13 AM
984runner's Avatar
I had the same shake on my 98 whenever I go above 60. I was afraid to drive faster than 70 because of the shakes. From the consensus on this forum, I had the shop replaced my steering rack bushing. That was almost two years ago. I was shocked that a few pieces of worned out rubber could cause that. I take my truck to 90s sometimes and it's smooth sailing. You should try replacing the steering rack bushing first because parts cost you less than $20 and if you can do it yourself, that's even better.
If you want to do it yourself, there is a good writeup at :
http://www.4x4wire.com/toyota/mainte...ering_bushing/
btw, I got the steering rack bushing kit from energy suspension.
Old Apr 22, 2008 | 06:54 AM
dirtoyboy's Avatar
What kinda shape are your steering and front suspension components in?
Old Apr 22, 2008 | 07:06 AM
Skrillah's Avatar
I'm actually about to do mine. Did you just go to the energy suspension website to get them? Their site doesn't seem to user-friendly...
Old Apr 22, 2008 | 07:53 AM
2000t4rAKS's Avatar
Yea, I have to do mine as well. I have been on the energy suspension website and you are right, NOT user friendly as well. Very difficult to navigate through the parts list and what not. I was going to go with www.wheelersoffroad.com steering rack bushings. It's a very good price as well.
Old Apr 22, 2008 | 08:00 AM
norcalsvx's Avatar
out of balance tires will shake at certain speeds not all the time (unless they are waay far out) have them re balanced a weight might have came off-
Old Apr 22, 2008 | 08:03 AM
Ron Helmuth's Avatar
When you have your alignment checked the next time see if your tie rod ends have excessive play.
Old Apr 22, 2008 | 08:14 AM
984runner's Avatar
I got them off Ebay at the time.
Old Apr 22, 2008 | 01:12 PM
twitchee2's Avatar
got the tries balanced real quick and problem solved
Up&Down
Aug 11, 2015 10:04 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 1, 2015 01:55 PM
terminator
Jul 27, 2015 07:13 PM
